How to adjust headlights - Ford Truck Enthusiasts Forums
Old 06-17-2009, 07:11 AM
1966Tbird's Avatar
1966Tbird 1966Tbird is offline
1966Tbird is starting off with a positive reputation.
i got new headlights from my parts truck since one of my original headlights caught on fire my truck is leveled out so i need to adjust the headlights angle down so i don't blind other drivers, i tried to do this with a 4mm socket and the socket just started to knock the sholders off of the adjuster bolt, is there an easy way to do this?
if not then keep in mind that i am good with a welder, sawzall, grinder, torch, and have a HUGE hammer
Old 06-17-2009, 07:29 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I don't know if your 89 is like my 95. On mine the adjuster sticks up about an inch. I couldn't find a socket or wrench etc that would fit it either. I just used a small pair of vise grips and adjusted them to fit snugly but not real tight.
Old 06-17-2009, 07:50 AM
1966Tbird's Avatar
on mine the vicegrips just won't grip the adjuster
Old 06-17-2009, 08:42 AM
BigSix1 BigSix1 is offline
BigSix1 is gaining momentum as a positive member of FTE.BigSix1 is gaining momentum as a positive member of FTE.
Quote:
Tbird,
Autoparts stores do sell a small "wrench" for those adjusters--it looks like a shorty screwdriver. But the adjusters on my '88 are so frozen, I can't get them to move, no matter what I do--and that's after "soaking" the adjusters, by trying to shoot PB Blaster down the shafts of the adjuster rods, hoping it got to where it needed to be. So far, no joy.
Perhaps the wrench will work for you, though?
BigSix
Old 06-17-2009, 10:33 AM
mstngmikegt's Avatar
mstngmikegt mstngmikegt is online now
mstngmikegt is starting off with a positive reputation.
Tip about the specialty wrench is a good one..I have one (only cause it was on clearance for a buck..). Biggest issue with the adjusters is that they freeze in place. Presoaking and patience is key. When they are as they should be, they turn easily. If that doesn't work, there is always the BFH and the checkbook.
Old 06-17-2009, 12:54 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
Sorry Tbird, don't mean to hijack your thread, but this is directed towards you also.
Can someone please take a picture of the adjustment thingy you guys are talking about? My truck's headlights need to be adjusted (they have for years, I just rarely drive at night).
Thanks!
Old 06-17-2009, 10:24 PM
1966Tbird's Avatar
they are the little bolt thingie that goes into a plastic hole lol i'll see if i can snap a picture
Old 06-17-2009, 10:28 PM
6CylBill's Avatar
Thanks Tbird, appreciate it man.
headlight pivot socket xoloski 1987 - 1996 F150 & Larger F-Series Trucks 18 02-01-2015 03:46 PM
99 Ranger headlamp adjustment? cabo169 Ranger & B-Series 5 03-28-2008 03:51 PM
Headlight Adjustment sergeant2 Explorer, Sport Trac, Mountaineer & Aviator 4 05-23-2005 09:51 PM
adjusting headlights superpelly 1997-2006 Expedition & Navigator 2 03-20-2005 06:58 PM
Manually Adjusting your headlights - aiming point ohiowhitetail General Automotive Discussion 6 10-26-2004 08:32 PM
Tags
89, adjusting, f150, headlights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
