Speedometer sending - electronic gauge
Old 06-17-2009, 01:38 AM
ShamelessMT's Avatar
ShamelessMT
ShamelessMT is offline
I've searched all over this site and others and can't find the answer...
I just won a set of 6 Aurora gauges and since I was planning on switching out my stock gauges anyway (though I was going to go with AutoMeter gauges, I can't complain about free gauges) this is awesome. The problem is that the speedometer in the set is electronic and not gear driven. How do I convert to this setup?
The truck in question is my 1976 F250 4x4 with a C6 transmission.
Old 06-17-2009, 02:43 AM
ShamelessMT
I just realized (went and looked) that the speedo cable attaches to the transfercase, so I guess I'm looking for a sending unit for a NP205? Anybody know how to solve this?
Old 06-17-2009, 03:11 AM
bmarkline's Avatar
bmarkline
bmarkline is offline
Try dakota digital - I hope I spelled that right. They make all those electronic digital guages- even for our dent side trucks so I'm sure they would have what your looking for.
Old 06-18-2009, 06:56 AM
Welsch69's Avatar
Welsch69
Welsch69 is offline
Shameless, I have the same speedo cable set up on my 75 F250. The original Ford part number is: D4TZ-17260-D, Connector Type C for the cable. I know you're not going for the original, but you may be able to cross reference using the original cable part number. Hope this helps.
Old 06-18-2009, 07:45 AM
ShamelessMT
Well, I spoke with their technical support and the gauge is supposed to be coming with a sensor. Whether it will work or not for my truck is still unknown, but I guess I'll see in a couple days when the gauges arrive.
Old 06-18-2009, 08:15 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I'm not sure in your case, but some digital speedos use a magnet that attaches to the rear yoke and a sensor mounted on the tranny, and senses speed off of that.
Josh
Old 06-18-2009, 08:51 AM
75F350's Avatar
75F350
75F350 is offline
Pulse generators are available through most transmission shops. These attach to the existing cable, and are just a converter. YOur new speedo will run off of the electronic converter and you are all set. Small little box that the cable plugs into with a couple of wires attached.
Old 06-25-2009, 02:55 PM
ShamelessMT
I guess I need to try this method, as the gauges arrived today and the sending unit they sent me isn't even close to the right thing. I believe it's for a Chev transmission and it's not even possible to modify it to work.
HILLBILLY BOB
56
12-22-2016 01:12 PM
catto95
01-20-2016 11:01 PM
HILLBILLY BOB
12-29-2015 12:01 PM
ms_michelle
Large Truck
16
01-01-2012 12:08 AM
peterbilttrucker
27
05-03-2009 02:01 PM
Quick Reply: Speedometer sending - electronic gauge
