Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-17-2009, 12:24 AM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
Removing Carbon from Pistons
I tried a search but didn't find an answer. I am 'overhauling' a small V-6 and after mic-ing the bores & pistons, found that I can re-use the pistons. What is the best way to clean them (on the bench)? The manuals that I have all say "do not use a wire brush to clean any part of the piston". I have had them soaking in my solvent tank for 2 days now and that has not had any effect. The solvent that is available here is not what it used to be.
  #2 (permalink)
Old 06-17-2009, 05:00 AM
doug1222556's Avatar
doug1222556 doug1222556 is offline
doug1222556 is gaining momentum as a positive member of FTE.
I used some Easy-Off oven cleaner and it took the carbon off, but it also caused the pistons to scale, so it probably did more harm than a wire brush.
I can relate to the solvents. The stuff I put in my parts washer wont cut dust. I bought a kitty litter pan and a couple of gallons of kerosene and clean up everything that way.
I think that "don't use a wire brush anywhere on a piston" is a load of crap anyway. Steel wire-yes. I have a fine wire brass wheel on my bench grinder and it doesn't seem to hurt aluminum at all. Stay above the top compression ring and I guarantee no ill effects and it will make them look like new.
If the pistons are off the rods, you can put them in the dishwasher while your wife's not looking and clean up a lot of stuff off them that way. (The rods will surface rust).
  #3 (permalink)
Old 06-17-2009, 08:48 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Wire wheel them, they don't need to be polished just get rid of all the heavy carbon.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #4 (permalink)
Old 07-03-2009, 07:24 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
Did you try MEK by chance? (Methel-ethel Keytone, I think) It's available at Home depot in the paint section. Just don't get it on your hands, clothes, or anything plastic.
I also second the kerosene trick, and found that if you add a can of seafoam or GM top engine cleaner to it it helps as well.
__________________
'98 EB Expedition
'08 Mazda MX-5 w/ Cosworth Supercharger
'69 Mach1 Mustang
'40 Chevy Pickup rust bucket project
'79 Wetbike * '94 Waveblaster raceboat
'01 Bluewater Skiboat
  #5 (permalink)
Old 07-03-2009, 11:27 PM
Thanx for the tips guys. I finally succumbed to using my wire wheel - just to get the carbon off - and then set them in Purple Power for a bit. That stuff works a whole lot better than my solvent! Anyway, they came out good and clean and don't appear to have suffered any from the wire wheel.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
