1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Truck shaking while accelerating through turns... a little help
Old 06-16-2009, 10:21 PM
santacruzf250's Avatar
santacruzf250
santacruzf250 is offline
Hey guys,
Might sound like a dumb question to some of you but hopefully that means it'll be easier for someone to help me figure out the cause..
I've got a 2002 Reg Cab F250, 7.3L...
When I go around turns and accelerate, the steering wheel shakes pretty hard and steering is difficult. Does this sound familiar to anyone?
It just started happening....
Ball Joints? hmmmm
Thanks!
Old 06-16-2009, 10:23 PM
santacruzf250
forgot to mention, no weird sounds, just the shaking.
Old 06-16-2009, 10:51 PM
sonofafordman's Avatar
sonofafordman
sonofafordman is offline
Santacruz250
Ok don't mean to insult you but I always start with the easy stuff. Is the truck accidentally in 4 wheel drive and your indicator light is not working. Or did someone play with the hubs and turn one without the other. Have you looked at the power steering pump to see if is functioning properly.
Old 06-16-2009, 11:06 PM
santacruzf250
HI,
Not insulted, thanks for the response.
Never had an issue the power steering, fluid levels are good.
Hubs are open, definitely in 2wd.
What's next?
Old 06-17-2009, 12:06 AM
sonofafordman
santacruzf250
Ok so you said you felt in the steering and not the whole truck. So rear transfer case seems unlikely. Could be the ball joints but I always thought they made the steering feel sloppy along with the shake. I had a brake caliper become loose. And it would slop over and rub that the only reason I noticed it. Yours might be slipping over when you turn a corner. They would make a noise but sometimes over diesel may not be noticeable. You may want to have someone turn a corner with you outside the truck to listen for a noise. Or just jack up the truck and spin the tire.
Atwiss
05-17-2011 12:51 PM
robs01f250
05-16-2011 01:18 PM
BbBlu250
10-23-2003 03:43 PM
Gladiator
08-11-2003 08:21 AM
Rat wagon
04-26-2003 12:14 PM
Quick Reply: Truck shaking while accelerating through turns... a little help
