help on 4.2 oil pan removal
Old 06-16-2009, 09:55 PM
Doxy's Avatar
Doxy
Doxy is offline
I have a 1998 f-150 2 Wd with a 4.2l and stantard tran. Anyone have a better way to remove the oil pan other than revoing the engine? I am have oil pressure problems and want to clean the pick up.
Thanks
Old 06-16-2009, 10:17 PM
ssquints999's Avatar
ssquints999
ssquints999 is offline
not sure about a 4.2 but i have been to with the 351 you can loosen the motor mounts and jack the motor up until you have enough clearance to drop the pan and slide it out.
Old 06-19-2009, 04:51 AM
bokker's Avatar
bokker
bokker is offline
hi, some one might know of a way but i just cannot see how it is posable. there is no gasket on the sump its only sealant and it is a tricky job on the engine cradle due to the few seconds you have to get face to face before sealant fails.
a machanical gauge is the best way of checking oil pressure as the pressure switch some times gives fault.
check for antifreeze in the oil this also can flag-up a problem. good luck bokker.
jchandler11
1997 - 2003 F150
05-15-2017 07:39 AM
lineman21
1997 - 2003 F150
02-27-2016 10:24 PM
ch88250
06-12-2012 04:37 AM
oldcoupe42
34
07-07-2010 08:10 PM
gearheadz80
3.8 & 4.2L V6
11-17-2005 11:26 AM
Quick Reply: help on 4.2 oil pan removal
