Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-16-2009, 10:15 PM
familyman65 familyman65 is offline
familyman65 is starting off with a positive reputation.
EAB head installation?
All you flathead gurus, I need to know if there is anything special to do when installing heads. I had to pull the heads and intake to clean some stuck valves. I know the tightening sequence, and to put a sealer on the head bolts, other than that I don't know. I have metal gaskets from the late 60's . It's an 8ba block, eab heads, and domed pistons 90 over. Any info would be greatly appreciated. Thanks, Kent.
  #2 (permalink)
Old 06-17-2009, 12:12 AM
Snowking's Avatar
Snowking Snowking is offline
Hail to the king baby
Snowking has a good reputation on FTE. Snowking has a good reputation on FTE.
I believe you got the bases covered except for machine work. At least thats the way i always installed heads.
__________________
2001 Ford F250/ V10 4x4 1969 Ford F100/ 300
1967 Ford F100/ 352 4spd 1957 Ford F250/ 292
1952 Ford F1/flathead 1950 Mercury M135
1949 Mercury M47 1947 Mercury half ton
  #3 (permalink)
Old 06-17-2009, 10:00 AM
Ok, I guess I made it sound like I know more than I do. The last time I worked on a flathead was 35 years ago. This engine to be exact. I can't remember much of the process. I was only 17. I don't know what to put on the bolts only that in one of these threads someone said they needed sealed. So what is something good to use? Can I use it on the head gaskets also? Thanks, Kent
  #4 (permalink)
Old 06-17-2009, 11:53 PM
Snowking's Avatar
Thread Sealant. The head bolts are apart of your water jacket so you seal the threads to prevent coolant loss. Not a mandatory step but a smart one.
__________________
  #5 (permalink)
Old 07-01-2009, 04:15 AM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 is starting off with a positive reputation.
yep lots of it ! i didna put any on mine and am beginning to wonder if it wasnt the cause of mine { head gaskets } to start leaking . dain newb's we don't know squat .........
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
  #6 (permalink)
Old 07-02-2009, 07:58 PM
What would be a good brand of thread sealant? Permatex # 2, or ???. Once I get the carb rebuilt I will be installing the heads . Hopefully within a week or so. Thanks
Tags
eab , ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
