Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-16-2009, 09:49 PM
pipman76 pipman76 is offline
pipman76 is starting off with a positive reputation.
Tci constant pressure valve body
has anyone used this ,i have decided to keep my aod behind my 5.o and use 373 or 4.11 gears in my 58 f-100 which gears would u guys use will the rpms still be low enough for cruising with the 4.11s i just thought it would be better to use the aod and for my relief of burning my tranny up ill try thr constant pressure valve body
  #2 (permalink)
Old 06-25-2009, 10:04 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
I have a TCI trans and 3.55`s and the overdrive kicks in around 50 mph. I think if you put 4.11`s in , yours in overdrive would run like mine does in 3rd,which aint bad unless you like to drive @ 75 for long distance`s. The vb sounds like a good thing to prevent trany problems.
  #3 (permalink)
Old 06-25-2009, 10:42 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
OK.. sounds like it might be an OK idea but really not necessary, you still have to connect the TV cable and it's really not much trouble to set it up right.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
