373 rear end in an F450 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 06-16-2009, 08:38 PM
whporwil whporwil is offline
whporwil is starting off with a positive reputation.
I saw in a post where someone put 373 gears in an 08 F450. Since that person dosen't want private messages has anyone else done this and has it helped with there mileage. I just traded an 08 F350 with the 373 for a 08 F450 that has the 488 in it because I needed to carry more pin weight.
Old 06-18-2009, 09:40 AM
F250Wheels F250Wheels is offline
F250Wheels is starting off with a positive reputation.
I installed 3.73 gears in my F450 and like it. I haul A 3000 pound camper and tow A 7000 pound trailer.
Old 06-18-2009, 10:20 AM
You were the one I wanted to contact about this, If your willing I would like to know what's required to do the job. My 373 rear end in my 350 pulls our camper just fine but were short on carring capicity on the back end.
Old 06-18-2009, 11:48 AM
I didn't know I can't receave pivate messages, I would change that if I know how. I got the gears for $1200 dollars frnot and rear and installed them my self. the original speed pickup will not work in the rear end with new gears, i machined A spocket to go on the out put shaft of transfer case and made a bracket to hold pickup mounted to trasfer case.
Old 12-18-2010, 12:45 AM
superdutytt superdutytt is offline
superdutytt is starting off with a positive reputation.
Question 450 gears
i just purchased an 08 f450 with 4.88 gears and i would like to change them to 3.73 or 4.10 what all did you have to do and where did you get your gears?
Old 12-18-2010, 08:23 AM
Texas450 Texas450 is offline
Texas450 is starting off with a positive reputation.
Hey guys I am intrested as well. Would there be a problem pull 24000lbs every once in awhile with 3.73? Also what is the rpms @65mpg? Thanks.
Tex
Old 12-18-2010, 12:56 PM
I got the gears from unitrex in Aneheim ca. It would pull 2400 fine just down shift more. With 3;73 gears im turning 1900 RPM @ 65 MPH I was going to go with 2.90 gears, but not all gears are avallible for the front Dana 60. I did the gears myself, other than the extra weight it's an easy rearend to work on.
Old 12-18-2010, 03:53 PM
Quote:
You put 2400 but I'm hoping you meant 24k....I don't pull that often but when I do its heavy. If a hurricane hits the texas or La. Coast I could be in for a long month of pulling 24k lb generators. I do want to drop gears but still need to pull the heavy weight. Right know at 65mph I'm at 2400 rpms! That's got to be killing my mph...what kinda mpg are you getting and are you tuned w a dpf delete? Thanks dude
Old 12-18-2010, 05:41 PM
Yes I meant 24000. I get 13 to 14 empty, 9 to 10 with camper and trailer. I was getting 9 empty and 7 pulling trailer with 4.88 gears. I have no tune, maybe when warranty runs out.
Old 12-18-2010, 06:42 PM
I understand that Ford has two different rear ends in the 450. Mine didn't have the cover plate on the back and the shop I was talking to could not do the conversion.
I'm getting an avarage of 8.5 pulling 15,000 lbs and 12 to 13 empty with my 4.88. I try to travel between 60 to 65 mph and agree that 65mph is 2500 rpm. My truck happens to be a 4x2 which might make a difference. I can tell you that the 4.88 in my 450 makes a lot more noise than my 350 with 3.73 did because of the difference in the rpm's, both trucks are 08's
Old 12-18-2010, 07:01 PM
I'm getting 13~14mpg empty w/ 4.88, a tune, dpf delete, and a afe2...now I'm real curious what I kinda mpg I can achive!
Old 12-18-2010, 07:14 PM
When you put those 3.73's in did you have any problems with the abs or anything. Did you have to modify anything!
Old 12-18-2010, 09:39 PM
read post #4
Old 12-19-2010, 10:45 AM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Quote:
Tex
Considering the kind of work you do I think I'd opt out of the gear change and install something like a Gear Vendors overdrive. That way you still have those deep gears when you need to haul heavy, and the rest of the time you can run the overdrive for lighter loads and/or better mileage. I had one of those (still have it actually) in an old 7.3 and it was the bees knees.
The thing with a gear change is you are stuck with what you get, whereas with the OD unit you can have it all.
Old 12-19-2010, 11:36 AM
gear venders aren't cheep, but if you haul alot the low gears are nice to have. I'm only grossing out at 20,000 total rig weight.
Gear change in F450? texasjack Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 10-07-2014 01:20 PM
What 4spd Clay101196 1967 - 1972 F-100 & Larger F-Series Trucks 43 05-15-2014 12:55 PM
Swapping 08 F450 Fat Boy 4.88 rear end into 08 F350 Farvardeen 1999 to 2016 Super Duty 2 07-23-2013 10:24 PM
Towing 2011 / 2012 F-350 Dually nyparrothed Fifth Wheel & Gooseneck RV Towing 11 10-10-2011 03:40 PM
How to get door code for 2008 F 450. weekendwarriorfsw32 1999 to 2016 Super Duty 8 07-01-2009 12:12 AM
Tags
1996, 2003, 2008, 373, 450, 97, axle, change, changing, diff, end, f450, ford, gears, parts, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
