Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 07-24-2009, 03:30 PM
TheWingnut's Avatar
TheWingnut TheWingnut is offline
1983 Ford F-250
TheWingnut is starting off with a positive reputation.
Just saw this thread
I wish I would have seen this before my attempt, but here is mine..........
  #32 (permalink)
Old 08-11-2009, 12:59 AM
Carbonero's Avatar
Carbonero Carbonero is offline
Carbonero is starting off with a positive reputation.
Nice job, Em! My own dash panel needs a similar treatment, so I'll "borrow" a few of your ideas and give it a try. I have no speaker in the dash anyway, so why do I need that ugly bunch of hole? The smooth dash looks so much better.
Repped
  #33 (permalink)
Old 08-17-2009, 10:49 PM
oddshot oddshot is offline
oddshot is starting off with a positive reputation.
FAR OUT!!!
This is quite a trick.
However ...
I'm more into utility then I am looks ... It occurs to me that there is a LOT of wasted space in one of these trucks ...
I wonder if I could trim out that hole and find some sort of pan or bin or something ... and fit it into the hole ... the fill the hole nicely with filler as you did.
I measured the area and a pan or ... something ... 6" X 7" ... and maybe an inch or two deep will fit nicely. Whatever pan I found would rest on the speaker mount.
Just a bin to toss stuff into.
Whatever I use ... it would have to be non-reflective and be able to stand up to the heat of the sun.
Just a thought ...
oddshot
  #34 (permalink)
Old 08-17-2009, 10:52 PM
first today's Avatar
first today first today is online now
first today has a good reputation on FTE. first today has a good reputation on FTE. first today has a good reputation on FTE.
Has anyone thought about a pop up 7 inch dvd player with the top of the player painted to match the dash?
__________________
Call me Kyle
_____________________________
  #35 (permalink)
Old 08-18-2009, 10:55 AM
Quote:
This is a GREAT idea ... do you have a picture of one of these things ... or an idea where I might look at one.
I wonder how it would stand up to the heat ... I got a boom box that has a CD player in the top ... I use it when I'm working outside.
One day after working outside ... I found that the door warped from the direct sun on it. It still plays but it ain't right.
A CD player mounted up there would be in the sun all the time.
oddshot
  #36 (permalink)
Old 08-18-2009, 11:02 AM
Wal mart has the DVD players for around 100.00. They are made like a laptop computer and about an inch thick. you could run all power wires right under the dash and play your movies through your stereo speakers.
I am sure it is illegal to use while driving, unless you swivel the screen towards the passenger. These units do swivel.
http://www.walmart.com/catalog/produ...ct_id=10980580
__________________
Call me Kyle
  #37 (permalink)
Old 08-30-2009, 02:34 PM
Like I said ... my Ford ain't about good looks ... as much as its about utility.
There is SO much space in the cab of a Ford does goes to waste!
anyoldways ... as per all your hints and tips ... I cleaned up the dash ... cut the hole ... braced up the bottom of the dash with fiber glass around the hole ... mounted it back in the truck ... taped and masked every thing off as I wanted ... greased up the tray ... and filled it all in with foam.
The old speaker mount acts as a support for the bottom of the tray.
I let it cure ... pulled the dash back out ... removed the masking , cleaned off the grease ...
Now I'm gonna fill in the cracks with bondo. I'm gonna use bondo ... to make the hole the tray fits in pretty ... then I'll paint the whole thing.
A tip ... there were a couple of spots where the dash covering was cracked and loose ... to anchor that down ... I lifted up the edges ... and filled under them with "Goop" adhesive. I "clamped" it down with duct tape and let it cure.
When I CAREFULLY removed the duct tape ... the Goop held the cracks almost perfectly closed ... nice and solid with NO FLEX. You almost couldn't see the crack.
Then I took a drill with a 1/8" bit ... and drilled a hole at the very end of each crack ... this SHOULD keep the crack from expanding.
Then I took my Dremel with a grinding bit ... and ground a "V" shaped grove following the crack ... do give a good site for the Bondo.
Then I block sanded along the crack ... to make SURE that every thing was FLAT.
Now I'm gonna go ahead and put in the bondo filler.
Check it all out ... put down a second coat where needed ... sand prime ... install.
I'll post the pictures when done.
__________________
oddshot
82 Ford F100 302, 4X4, 4Spd
72 MGB-GT 1.8 4 Cyl, Nissan 5 spd, TBI.
72 MGB Roadster 2.8 GM V6
99 Blazer Grocery Getter
99 Mercedes Benz 500 SL Roadster (the wife's car)
Tags
howtofillinthespeakerholescracksinyourdash
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
