Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-16-2009, 06:15 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Better Filtering system needed
Attached are pics of my filtering setup. I had been gravity feeding through sock filters, but it was really slow. I got a threaded piece from Duda-Diesel that the sock fits over (was a bear to get all three on it). Anyway, thought that it would be faster to push the bio through, but it leaks oil up and over the fitting, so didn't go near as fast as I had hoped. I am using Magnesol to dry-wash, so I filter down to 1 micron. Does anyone have plans that they would share for a better setup? thanks.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 06-17-2009, 09:43 AM
Knotwild Knotwild is offline
Garage is empty, add now
Knotwild is starting off with a positive reputation.
I am using Magnesol to also and I tried different ways of filtering with socks and spin on filters to save money. I finally got tired of the failures and bought a poly filter housing from Fryer to Fuel and it was worth every penny. I filter to 1 micron nominal each time I move the fuel and to 1 micron absolute when fueling the truck. Settling the fuel at least 24 hours after mixing the Magnesol is also a big help.
100XB Filter Housing at F2F Filtration Units
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #3 (permalink)
Old 06-17-2009, 10:06 AM
Rushmore X's Avatar
2003 Ford Excursion
I settle mine @ least 12 hours, and have the pump set about 3-4 inches above the bottom so it shouldn't suck up any magnesol. thanks for the link, I'll check it out!
__________________
  #4 (permalink)
Old 06-17-2009, 11:39 AM
Trent: This is a link to a picture of my processor when I first started with it, so the filter housing is not present. PROCESSOR on Flickr - Photo Sharing! I push the fuel into the elevated stock tank where I demeth it by aeration, settle out glycerin and soap, and then gravity through socks into the tote. Then I clean the glycerin and soap out of the tank, and return the fuel to the tank for Magnesol treatment; settle for a minimum of 24 hours, gravity through socks again, and pressure to storage tote. This is a picture of my Magnesol being stirred. My magnesol never goes through a pump. Magnesol mixing pump running on 75 gallon batch. on Flickr - Photo Sharing!
Each time I move the fuel it goes through the filter housing. The housing is not cheap, but it makes the process much easier for me.
__________________
  #5 (permalink)
Old 06-17-2009, 05:49 PM
Rushmore X's Avatar
2003 Ford Excursion
Also helps if the pick-up tube doesn't slide down. Mine did, and it was sucking up Magnesol. Filter was totally plugged. Put on the other set of bag filters, made sure it didn't slide down again, and pumped out 20 gallons without a problem. I still would like a setup similar to yours, either that or use a centrifuge. thanks again for the pics!!!
__________________
  #6 (permalink)
Old 06-17-2009, 06:58 PM
I thought about a centrifuge, but a good one is a little over $500. only runs 0.9 gal/hour, and you have to make two passes. I use vacum and pressure to move my fuel around. Once it the Magnesol is settled it gravities through the socks into the tote which catches any Magnesol that might be stirred up (which is very minor). When I blow it through the 1 micron absolute I am done.
I have to admit I don't mind spending a little more to make things easier, plus I hope to be making fuel long term.
__________________
Tags
100xb, biodiesel, demeth, ebay, filter, filtering, housing, magnesol, quickly, setup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
