Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-16-2009, 07:06 PM
Mustangtoby2001 Mustangtoby2001 is offline
Mustangtoby2001 is starting off with a positive reputation.
Duramax?
My company truck is an 08 6.4 PS, 52,000 miles, and the engine went out. So now it's at the Ford Store getting a new engine, and the Boss gave me an 08 Duramax to drive in the meantime.
I am VERY hardcore Ford, so I'll do my best to leave the bias aside. This GMC runs like a scalded cat empty, I know it would outrun my PS. But as soon as you put a little weight on it, it turns into a dog. Even an empty trailer. I drove my personal truck for a week (06 F 150, 5.4 4x4), and pulled the same trailer. I think the 1/2 ton lost less performance pulling the same trailer empty! I've never seen anything like it. Pulling a skid steer up a hill (about 7500 lbs) it was really working it, same load up the same hill in the PS or a Cummins and I can go faster than the road will allow. What's up with this? Are they all this way? It is a 2008 4x4 4 door long bed with 22,000 miles on it, and runs very strong empty. Maybe just really high geared? What do you guys think?
  #2 (permalink)
Old 06-16-2009, 07:35 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
I've heard similar things about the Duramax from various towing reviews. its quite odd.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #3 (permalink)
Old 06-16-2009, 07:43 PM
ruschejj's Avatar
ruschejj ruschejj is offline
2008 Ford F-250
ruschejj is starting off with a positive reputation.
I had an '05 3500 and I can say that it was similar to what you are saying. No lag from the turbos, I'm not so sure that the turbo even did anything at low rpm, all motor and it took off quick.
I think GM has a weird set-up with the little 16" wheels and the Allison trans. Nothing bad to say about GM but I sure do like my 6.4. I especially like the truck in general and I have had a great experience with the 6.4. I hate to see others have problems.
My F250 handles a 16K trailer far better than the '05 Chevy 3500 dually we had. Now I don't have to buy 6 tires, yippee.
__________________
'08 F-250 4X4 CC 6.4
RideRite Airbags in Rear w/onboard compressor
Bilstein Shocks, Dual Air Horns (under hood)
Edge Insight Gauge Cluster
4-Way "wig wag" strobe lights
Polk speakers, Kicker 10" sub, 600w amp
  #4 (permalink)
Old 06-16-2009, 08:13 PM
That's the way this one is, no lag. If you punch it, it will chirp the tires. My PS won't do that. I do understand why everyone likes the Allison now, but the rest of the truck don't compare at all!
My PS was kinda wierd. The turbo let go, and either bearings or fins from it went through the engine, ruining the whole thing. I should have it back Friday, Yippee!!!!!! I can't wait!
One other thing - My PS weighs about 10,000 lbs in daily trim, and the GMC doesn't have any tools or fuel, only weighs about 8,800. Just makes it look worse in my eyes. I live at 7,000 ft and work from 8,600 to 10,000 ft (Telluride, Co). I would really like to drive one of these at sea level at showroom weight!
  #5 (permalink)
Old 06-16-2009, 08:32 PM
senix's Avatar
senix senix is offline
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
The Dirtymax has different gearing and yes to go with less torque. TQ is what does the work, Horsepower is for get up and go.
The 6.4 is a little slow on take off simply because of the emissions imo. Put a tuner on it and then there is no lag.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #6 (permalink)
Old 06-16-2009, 08:57 PM
One other complaint about it, just my opinion. The cruise control is a pita, the AC is also. The headlights come on with the key if its cloudy (whether you want it or not), and you can't turn the seat belt chime off. If I had no Ford choice, I would buy a Dodge over GM.
I've put a lot of miles on a dodge at work, and didn't really care for it, to me the Cummins drives like a dumptruck. But after finally driving a GM, I don't see how they have any following. Thank god for Ford!
  #7 (permalink)
Old 06-16-2009, 09:02 PM
senix's Avatar
guess they never gave it any though about the use of the truck or maybe they did.
I think over 70% of Ford truck users are hunters/camper/fisherman...that is why you can keep the headlights off vs GM...grocery trucks.
__________________
  #8 (permalink)
Old 06-16-2009, 11:50 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Actually you can, you just have to do it thru AutoEnginuity or a similar product. You just have to program a module to get it done.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #9 (permalink)
Old 06-17-2009, 07:01 AM
Quote:
That's a pisser. Thank god I am about done with this thing. Of course, I had one heck of a time getting the chime turned of my 08 PS, just wasn't holding my mouth right. Oh well, I know I'm preaching to the quoir!
  #10 (permalink)
Old 06-18-2009, 06:40 PM
Dually TAS's Avatar
Dually TAS Dually TAS is offline
Dually TAS is starting off with a positive reputation.
Lucky you! I used to live in Hermosa, now we just vacation there.
__________________
2005 F-350 Lariat DRW 6.0 PSD FX4 Tow Boss
  #11 (permalink)
Old 06-18-2009, 08:50 PM
I love living here in the summer, the winter is only cool when I'm wheelin' in my Bronco!
  #12 (permalink)
Old 06-24-2009, 07:08 AM
Update: Got my PS back yesterday, got out of the GMC. Man, the difference is unbelievable, just how much more solid the Ford feels, how much higher you sit, everything! I am so happy to have it back!
By the way, you know GMC stands for Great Mass of Crap?
  #13 (permalink)
Old 06-24-2009, 07:31 AM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE. 150ford is gaining momentum as a positive member of FTE.
Yeh I always loved the way Ford sits higher then the others. Also the mirrors an the cuttout windows. Second to none when your viewing the rear. Glad you got your truck back.
__________________
BUILT FORD TOUGH
  #14 (permalink)
Old 06-24-2009, 06:07 PM
I've been pretty worried about it. The turbo went out on it, and pieces of the turbo went through the engine. They replaced the whole engine top to bottom, and the exhaust from the particulate filter forward. So far so well. I do have a check engine light this morning, but I found a sensor off of the muffler, hooked it back up, think all is cool now. If that's the only problem after an engine change I'll be happy!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
