Beeping sound in first couple minutes of driving - Ford Truck Enthusiasts Forums
Old 06-16-2009, 04:35 PM
kostyan44 kostyan44 is offline
kostyan44 is starting off with a positive reputation.
Hi All,
I own a 2003 Ford Explorer XLS V6 RWD. I have this issue going on which I cannot figure out how to fix:
Right after I start driving there are several (I think 3) short beeps - they come in sets - 2 or 3 sets within one minute and then the beeping stops and does not come back until next time I start driving (start the engine and go).
It's kind of weird - I checked all seat belts and door locks - looks like all that is in check. Any ideas on what this may be?
Alternatively - where is that little beeper \ speaker located? Is it to the right of the steering wheel?
Thank you all so much for your help.
KK
Old 06-16-2009, 06:10 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Your air bag indicator lamp is burned out. Once you replace the bulb you will find there is some other issue with the SRS. Count the air bag indicator flashes and post here for help.
Old 06-16-2009, 06:32 PM
Thanks for your reply ncranchero! I will check that out.
However - when I turn the ignition key once all the light bulbs come on and the Air Bag light is coming up as well. Am I talking about a wrong light?
KK
Old 06-16-2009, 06:40 PM
One more question - where is that beeping speaker located (the one that actualy makes the sound) - is it to the right of the steering wheel, right under the dashboard where the small grill (speaker grill??) is?
Once again - much appreciated.
KK
Old 06-16-2009, 06:44 PM
ncranchero's Avatar
Yes, the air bag light is the one I'm speaking of ...... strange. I'll look into the beeping being the same on the Explorer as on the F150 which I'm much more familiar with. I'm just getting into these Exploders...........
Old 06-17-2009, 12:35 AM
ncranchero - you were absolutely correct. I opened up the dashboard and the Air bag LED was actually physically broken off - who knows how that may have happened??
Anyhow - replaced it with a new 12V Amber LED - and it's working like a charm.
Thanks for your help, man.
KK
Lug Nuts and Studs Kelyn Brown 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 06-17-2016 04:24 PM
05 f650 Cummins Brake light on and beeping FredsTow Large Truck 9 09-15-2015 02:20 PM
F-650 No Start Hambone101 6.0L Power Stroke Diesel 10 03-13-2013 12:32 PM
PCV Elbow enriched&beyound Modular V8 (4.6L, 5.4L) 0 03-10-2011 07:00 AM
o god!!! dyoung14 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 11-29-2009 06:21 PM
Tags
1991, 98, air, bag, beep, beeping, board, dash, explorer, f150, ford, makes, making, mustang, sound, srs, start, turned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
