Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-16-2009, 01:19 PM
santaak santaak is offline
santaak is starting off with a positive reputation.
Egr
Can anyone tell me what year ford started putting the EGR system on The 300 six in a F150?
Thanks
  #2 (permalink)
Old 06-16-2009, 04:15 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
1981 Ford Bronco
AbandonedBronco is starting off with a positive reputation.
If I have heard correctly, it was 1978.
__________________
4bbl Holley 390 w/ Offenhauser DP intake. 4 speed Manual w/OD. K&N air filter, EFI manifolds, 2.5" exhaust.
3.00 rear end and 2000 RPMs @ 80mph!
Boise, Idaho
  #3 (permalink)
Old 07-01-2009, 07:54 PM
1978 EGR system
Thanks. Can you tell me where I could find out exactly what the EGR system existed of in 1978, on the 300 six in a F150 4X4?
Thanks for any help
  #4 (permalink)
Old 07-02-2009, 10:16 AM
1981 Ford Bronco
If it's anything like my '81 (which I'm sure it is), it's pretty simple. Between the 1bbl carb and the intake is a spacer with an EGR valve on the end of it. Then, there's a pipe coming out of the exhaust manifold which routes up into the underside of the spacer.
When the engine is under load, a vacuum line pulls open the EGR valve, which lets exhaust out of the EGR pipe back into the intake.
Not a lot to it.
__________________
Boise, Idaho
  #5 (permalink)
Old 07-02-2009, 12:41 PM
Thanks for the help. I traded for this truck, and its my first 300 six. Some one has done a lot of backyard work on it and I am just trying to figure out where to start.
Thanks again
  #6 (permalink)
Old 07-02-2009, 06:31 PM
Harte3 Harte3 is offline
Harte3 is starting off with a positive reputation.
Start at your local, friendly auto parts house and obtain a Chiltons or Haynes repair manual that covers the year and model of your truck.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
  #7 (permalink)
Old 07-02-2009, 07:50 PM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE.
It was earlier than that in California. Around when the EPA was formed.
My 1973 F-100 302-V8 had an EGR valve. Factory equipped.
My Father's 1976 300-I6 also had one.
But remember California was Special.
  #8 (permalink)
Old 07-02-2009, 07:53 PM
1981 Ford F-150
Not a lot to it.
You forgot the ported vacuum switch, that shuts the EGR off when the engine is cold. Hooked into the water jacket, at one of the fittings in the thermostat housing.
But agreed, not much to it in the early years.
  #9 (permalink)
Old 07-03-2009, 10:00 AM
1981 Ford Bronco
Ah yes. Wasn't that to keep it from opening the EGR while the engine was cold?
__________________
Boise, Idaho
  #10 (permalink)
Old 07-03-2009, 01:35 PM
Thanks
Thanks guys. I appreciate all the advice. My truck is in town for a couple of days getting painted. As soon as I get it back I will see what I can figure out.
Thanks again
  #11 (permalink)
Old 07-03-2009, 02:12 PM
One more ?
I have another ? What is the small tube that runs from the manifold up to the carburetor choke? Mine has been broken off and bent over to pinch it off at the carburetor end. How do I get the other end out of the manifold?
  #12 (permalink)
Old 07-03-2009, 02:33 PM
1981 Ford Bronco
That is the heat chimney for the choke. When the manifold warms up, it sends heat up the tube and warms up and opens the choke up. It works in conjunction with the electric choke, if you have one.
You can just drill it out, it's nothing more than just a indent in the manifold and doesn't go anywhere. You can bend some more tubing and run it out of the choke and into that hole. Or, you can just have the tubing exit the choke, and then wrap it around the manifold a couple times. Just as long as it's touching.
__________________
Boise, Idaho
  #13 (permalink)
Old 07-03-2009, 07:49 PM
1981 Ford F-150
Exactly.
The EGR can cause drivability issues with the engine cold.
  #14 (permalink)
Old 07-03-2009, 07:55 PM
1981 Ford F-150
Quote:
Just as AbandonedBronco described it.
Except depending on exaust manifold, there may be a choke stove inside the exaust manifold.
Filtered air goes from the top port of the carb opened to the airhorn, goes to the bottom of the exaust manifold, goes through the choke stove in the exaust manifold, another tube is attached to the top, and this one attaches to the carb at the choke.
I would get this working, as it also helps to keep the carb from icing up, if you live in a cold climate.
You can get aftermarket choke stove tube kits at most autoparts stores.
  #15 (permalink)
Old 07-04-2009, 04:00 PM
1981 Ford Bronco
Definitely. It's a great system to have operating. Not only does it help in cold temperature, but even on warm days, the velocity of the air inside the carb can get them cold enough to lower performance. However, since this setup doesn't have much to do with the EGR system, it's probably not disconnected.
__________________
Boise, Idaho
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
