New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Aftermarket Products SPONSORED BY:
06-16-2009, 10:55 AM
Locking Gas Caps
I recently bought a locking gas cap for my 2006 F250 diesel from Pep Boys. It appears there is not a Ford one. Is this really true?
I was wondering if anyone has a work around for the tie down cable that keeps the cap from falling when it is unscrewed?
06-16-2009, 10:55 PM
2002 Ford F-250
I doubt ford ever had a locking cap. I have a Stant locking cap, I once reused the OE retaining ring. The stock caps can come apart and the strap has a loop that goes around the cap. My stant cap has a groove that accepts it, but the red trim ring that should hold the ring to the cap kept coming loose.
I suspect a couple of drops of glue will keep the new cap together. However, I just deleted mine. If I were to need it again, I would drill a small hole in the cap, and use nylon covered SS fishing line to retain it.
06-16-2009, 11:33 PM
Ford does have locking gas caps. They are used for none North American vehicles.
__________________
2007 Diesel -F250 4X4 Lariet CC Long Box
-COLOR="red"]Toyo A/T 285/75 18-Bilstein HD -DieselSite Coolant bypass Filter -Autotruck Toys dual steering stabilizer -Quick motor oil dain plug ,
-High idle control -Reverse lights -Rotella 5w40 -24" wiper blades -Interior light shut off switch
06-17-2009, 01:24 AM
2002 Ford F-250
Do you have access to a part number or maybe who the OEM was on them?
06-17-2009, 02:58 PM
I work for Ford, here in Ontario. I am on holidays for two weeks but I could check when I get back June 29th.
__________________
06-18-2009, 09:37 PM
Locking fuel caps
Ford has one & the strap wraps aroundthe cap & is attached to the vehicle with a self tapping screw beside the filler tube. Try OEM Pt No F67Z9030DA
06-22-2009, 03:21 PM
When you get back from holiday is fine....Thanks
07-02-2009, 08:17 PM
Plump forgot about the part number for the locking gas cap. I'm back on Monday the 6th, I check for you then.
__________________
07-03-2009, 11:21 PM
Thanks...that will be great
07-04-2009, 09:23 PM
Did you check out F67Z9030DA. This is the part in OZ
07-07-2009, 07:36 PM
Locking gas cap part number 8L34 9K163 AA. These are the ones that are used with the Ford Edge, MKX, FLEX, MKT.
__________________
07-07-2009, 10:23 PM
I am away on a 2 month trip, when I get back, I will order one....
Thanks
07-08-2009, 11:24 AM
Sorry it took so long.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
