6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Anyone with similar a/c problems??
Old 06-16-2009, 09:52 AM
chi6488's Avatar
chi6488
chi6488 is offline
Dealer replaced my a/c controller about a year ago b/c the blower fan will shut off.
The problem is starting again. Saturday it shut off for a long time and I had to turn truck off and back on to get blower to work. Most of the time it shuts off for a few seconds and kicks back on.
Think it could be a bad fuse or relay for the blower?
Old 06-16-2009, 11:26 AM
PSDx3's Avatar
PSDx3
PSDx3 is offline
Sounds like the blower motor may be drawing too much amperage after it runs for a while then resets after it cools, or it could be a circuit breaker. I had the same type problem with headlights. After replacing numerous wires and connections it turned out to be a weak circuit breaker that popped to easily and then reset. Replaced the curcuit breaker and no problem since (4 years).
Old 06-16-2009, 12:09 PM
69cj's Avatar
69cj
69cj is offline
Next time it happens try turning the light switch on and off. If that corrects the problem the control head is probably going out again.
Old 06-17-2009, 06:34 AM
jrc55's Avatar
jrc55
jrc55 is offline
Mine did the same thing. A/C was still engaged but the fan would quit,replaced the control but, no fix, finally R&R the blower relay behind the glove box.
Old 06-17-2009, 11:33 AM
jasfaa's Avatar
jasfaa
jasfaa is offline
Had the same problem. I think it is probably a relay. As soon as you reset the system by turning the truck on and off the blower returns.
fixit5561
07-27-2010 01:59 PM
bigrigmike
04-08-2010 03:59 PM
Yelrisheam
09-27-2003 09:58 PM
dbuck50
07-10-2003 11:22 PM
Quick Reply: Anyone with similar a/c problems??
