1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How did Ford fix the Death Wobble in 08?
Old 06-16-2009, 05:44 AM
66 BADBOY's Avatar
66 BADBOY
66 BADBOY is offline
Hey guys,
First off, yes I did try searching this out, and I couldn't come up with a definite answer, so I thought I'd post some questions about it.
I've been reading on here, and saw a few posts saying that Ford fixed the death wobble in 2008 and up models. Then I see some people who own 08's were getting letters from Ford regarding the death wobble. So I'm kind of wondering "if Ford fixed it, why are the 08 owners getting letters about it?". And that leaves me with 3 questions:
1. Did Ford actually fix the suspension issues that cause the death wobble?
2. How did they do that?
3. Can it be retro-fitted on a 05-07.........or is the only fix for 05-07 new shocks and dual stabilizers?
Thanks
Old 06-16-2009, 07:42 AM
jimd1050's Avatar
jimd1050
jimd1050 is offline
Worry later? IT IS LATER!
Aftermarket FIX... that works!
As to question 3, these guys have a fix that works.
Super Duty Fix...
...and before I get more questions, that's one of the owner's trucks pictured and is not affected by the wobble. It's only in the picture as a FORD Super Duty built by their shop!
Old 06-16-2009, 07:48 AM
Downriver Thunder's Avatar
Downriver Thunder
Downriver Thunder is offline
I merely added a dual stabilizer to my 05 and it's fine now.
Old 06-16-2009, 07:54 AM
66 BADBOY's Avatar
66 BADBOY
Super Duty Fix...
I realize these are both fixes, but I'm mainly trying to find out if its fixed from the factory now on the 08's and up, and if so, can the same fix strategy be retro-fitted on the 05-07 trucks.
Old 06-16-2009, 09:41 AM
skip mitchell's Avatar
skip mitchell
skip mitchell is offline
I have an 06 F350 single rear wheels 4X4 as well as an 08,the 06 with 164k miles and has never done it,neither has my 08 but got a letter from ford on each truck like 2 days apart
Old 06-16-2009, 10:38 AM
redford's Avatar
redford
redford is offline
Received 1,562 Likes on 910 Posts
Can't say now, but I swear the death wobble letter I got from Ford included '05 to '08 trucks.
Old 06-16-2009, 11:19 AM
Fats95's Avatar
Fats95
Fats95 is offline
I looked over the one I received dated April 09,
Mostly just address F 250/350, only thing I see it states to prevent shimmy, maintain recommended tire inflation pressures. And do not make suspension modifications. I guess I screwed that one up.
Old 06-16-2009, 11:40 AM
Fats95's Avatar
Fats95
Fats95 is offline
<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1lace w:st="on">Redford</st1lace>, I noticed your signature block, we are geographically positioned in the same part of the world.
Old 06-16-2009, 12:26 PM
zman300's Avatar
zman300
zman300 is offline
That's a good question.
I've talked to 3 dealers, 2 said they were not aware of any shimmy problem with the F250, the third was going to do some research and get back to me, hasn't yet.
I emailed Ford got some generic response that didn't answer my question.
So I called Ford talked to a very nice woman but she was really no help.
No one I talked to will admit there is a shimmy problem. They say bring it in but if they don't have any idea what to look for what's the point.
They all talk about tire pressure, I know pressure could be a factor. But the death wobble is more than tire pressure.
These dealers are either dumb or Ford is instructing them to play dumb.
This weekend I'll go to the Ford lot look at some 09's see if the setup is different.
I'm not bashing Ford just telling ya all what happened.
Old 06-16-2009, 12:53 PM
semperstrokin's Avatar
semperstrokin
semperstrokin is offline
tsb
Isn’t there a TSB stating to install a different stabilizer, that is what they did on my 05 250 and the difference is night and day. I have kept the same tire pressure in the tires from day one. BTW I think they had to widen the frame to put the 6.4 in so that might make a difference.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 06-16-2009, 01:14 PM
FX4 5.4's Avatar
FX4 5.4
FX4 5.4 is offline
they didn't fix anything for 2008. I have a slight oscillation in my 05 but rarely have it at highway speeds. the mechanic that works for my dad has a 2008 F250 FX4 5.4 CC SB and a few weeks ago driving on the highway at about 70, he hit a bump and almost lost it. the wheel started shacking heavily and it was almost impossible to steer it while it was happening. he also received the shimmy notice from ford. hope this answers the OP's question
Old 06-16-2009, 02:07 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
I could be wrong and someone with an 08 and an 05 thru 07 maybe able to clarify but i believe Ford repositioned the stabilizer on the 08 and up. Again i am only repeating what i have heard. This relocation (if in fact it has been) was intended to help, minimize or eliminate the "death wobble" has it? I do not know but if it has been done i would like to think that Ford engineers did it for a specific reason.
Regardless if it has been "fixed", as FX4 5.4 states it still happens. Do what we all have done and replace the stabilizer with a quality one, single or dual. Replace the shocks when you feel they need to be replaced sooner than later and be done with it. It's a simple and cheap enough fix anyone that has a wrench can do.
Old 06-16-2009, 05:04 PM
zman300's Avatar
zman300
zman300 is offline
During the death wobble, what exactly are the front tires doing.
Bouncing up and down, in and out or both.
Old 06-16-2009, 06:21 PM
rmosso1's Avatar
rmosso1
rmosso1 is offline
Ford works in mysterious ways. Look under a 2008 with a 6.4 F-350. Under more specifically a wide track, as FORD calls it.
Beefed up. Heavier. BLACK SHOCKS. No death wobble from mine at around 14,000 miles.
In a similar post about how to measure your motor oil. DO YOU deep down think that FORD couldn't design a better dip stick, or do you think the dip stick does what is intended, and that is to confuse, as we know the 6.4 has leaky injectors.
SAME with the death wobble. Confuse 'em. We eventually give up. I raised my hands long ago.
Old 06-16-2009, 09:48 PM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
My '08 had it. Nothing that Icon dual steering stabilizer couldn't fix.
Quick Reply: How did Ford fix the Death Wobble in 08?
