Need pics/diagram of F600 door handle and latch - Ford Truck Enthusiasts Forums
Old 06-16-2009, 01:08 AM
bulletsneverlie bulletsneverlie is offline
bulletsneverlie is starting off with a positive reputation.
I need pics or a diagram of an F600 dent side door handle and latch system. Does anyone have them, or know where to find them?
I just got the whole setup from my grandpa's wrecked old '69 F100. I wanted to see how the F600 push button handles are designed and placed so I can fab up these handles and locks to work on my '74. I managed to get the ignition lock cylinder and key too, so the one key works for the doors and ignition. I think it will be great to be able to use these locks and this key that my grandfather has had for 40 years. My dad rode in that truck when he was a kid.
Old 06-16-2009, 03:17 AM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
Since there are a few F600 trucks owned by people on here, you're going to want to invest in a medium-duty truck parts catalog so you can find diagrams for everything.
Old 06-16-2009, 05:42 PM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
Here is a pic of the door handles that were installed on a 76 crew cab by a guy/ bendog on another crew cab forum....old ford crew cabs... he is doing a really sweet job building his 76 crew cab!!
Maybe you can contact him through that forum for more details
Old 06-16-2009, 10:40 PM
78f250lj's Avatar
78f250lj 78f250lj is offline
78f250lj is starting off with a positive reputation.
I think bendog used Econoline van door handles
Old 06-17-2009, 03:06 AM
Ok. Thanks, that sounds good. I actually found some of the info I need. I found some diagrams of the '84 push button handles. I imagine they work more similar to how the '70s push buttons do.
The '69s push buttons use a paddle in contact with the button, the '80s have a lever against the button, that is hooked to a rod, much closer to the '70s design. The lever and rod allow for more freedom of handle placement.
The '69 requires the handle to be placed in one particular location so that the button can directly push the paddle, and the lock cylinder directly lifts and lowers the locking mechanism. I believe the dent is in the way of where the '69 assembly locates the lock.
I'll think on it and get back to you guys.
Old 06-17-2009, 07:51 AM
78f250lj...I went back and checked...you are right, I guess I just assumed they were the sameas the f600 that I used to drive, at least they looked that way, wonder if the mechanicals are the same???
They look awesome on there!
Old 06-17-2009, 03:07 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Keyed alike door and ignition sets:
C7TZ8122050A .. Lock Set / Fits: 1967/72 F100/750. This set is not the same as...
D8TZ1022050D .. Lock Set / Fits: 1973/77 F100/350 / 1973/79 F500/750.
If both trucks have double sided keys, you can have your present lock cylinders re-keyed, so you can use grandpa's keys in your 1974.
The outside door handles used 1967/72 F100/750's are not the same as 1973/77 F100/350's, not the same as 1973/79 F500/750's.
C7TZ8122404A Right & C7TZ8122405A Left .. Outside Door Handle / Fits: 1967/72 F100/750.
D3TZ5022404A Right & D3TZ5022405A Left .. Outside Door Handle / Fits: 1973/79 F500/750.
D8BZ5422404A Right & D8BZ5422405A Left .. Outside Door Handle / Fits: 1973/79 F100/350 / 1978/79 Bronco / 1973/78 LTD/Mercury Marquis / 1973/76 Torino/Montego / 1974/76 Cougar.
Fits: 1974/78 Mustang II / 1975/80 Granada/Monarch/Lincoln Versailles / 1977/79 T-Bird/Mark V/LTD II/Ranchero/Cougar / 1978/83 Fairmont/Zephyr.
Rear hatch latch assby replacement "how to" w/pics ExxWhy Excursion - King of SUVs 13 12-15-2016 05:32 PM
1971 C600 Door Latch Joe Kelly 1967 - 1972 F-100 & Larger F-Series Trucks 13 09-20-2016 01:03 PM
door locks scottlathrop 1961 - 1966 F-100 & Larger F-Series Trucks 8 12-21-2013 06:46 PM
56 F100, photos of how the door lock and latch mechanism work, and remove and install. Aus56 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 12-04-2013 05:11 PM
Door Ajar Switch Wire Color Shadow351 1997 - 2003 F150 3 01-15-2011 12:30 PM
Tags
1974, catalog, door, dump, f100, f350, f500, f600, ford, handle, handles, latch, parts, truck, trucks, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
