2003 6.0l f250 trouble code p0263 - Ford Truck Enthusiasts Forums
Old 06-15-2009, 08:41 PM
guidry23's Avatar
guidry23 guidry23 is offline
guidry23 is starting off with a positive reputation.
Question 2003 6.0l f250 trouble code p0263
I pulled codes on 2003 f250 6.0L and got
P0263 cylinder 1 contribution balance
P0266 cylinder 2 contribution balance
P0404 EGR circuit malfunction
P2269 water in fuel
should i get a check engine light with any of these codes?
and if so what do i do, and how detrimental are these codes to the truck
Looking for any information on these codes, really i am looking for what they really mean.... any response will be helpful
Old 06-15-2009, 08:43 PM
liv liv is offline
liv is gaining momentum as a positive member of FTE.
I would focus on PO404 and P2269 I would imagine the 3 first ones would throw the check engine light on. The last one should throw the Water In Fuel light on.
Clean/replace your EGR valve and it should clear the 404 code. Drain your FICM and it will clear the 2269 code. Don't forget to change your fuel filters. Instructions for all the above are in the Tech Folder at the top of our section
Old 06-15-2009, 09:25 PM
jboczar jboczar is offline
jboczar has a good reputation on FTE.jboczar has a good reputation on FTE.
I would worry about the injector codes, is your truck running rough cold or hot? If it is only running rough cold then the revised cold start strategy program should correct this concern. Cleaning your egr valve is a good idea for the p0404 which is a performance code. For the water in fuel light, sometimes draining your frame mounted fuel module is insufficient. Debris likes to collect behind the cover in front of the sensor and sometimes you have to remove it and clean it out by hand but by all means drain if first and try that. its a 6mm allen wrench to remove the plug.
Old 06-16-2009, 09:30 AM
guidry23's Avatar
Question
what is the revised cold start strategy program ?
Old 06-16-2009, 10:29 AM
M.Farragher's Avatar
M.Farragher M.Farragher is offline
M.Farragher is starting off with a positive reputation.
Dumb question
I know this is a dumb question, but there are numerous references to the "tech folder", and I would just like to ask where this most valuable folder is hidden. On my screen, there appears nothing titled "tech folder". Probably just one of those website in the know things, but I'd like to be in the know.
Thanks,
Old 06-16-2009, 02:02 PM
eddiedebb's Avatar
eddiedebb eddiedebb is offline
eddiedebb is starting off with a positive reputation.
Old 06-16-2009, 10:24 PM
Revised cold start strategy is a program from Ford that tells the Fuel Injector Control Module to energize the coils at the same time to heat the injectors up quickly to eliminate the spool valves sticking internally and causing misfires on cold starts. A very common problem, the program fixes about 90% of running rough when cold issues.
EGR Delete, Fuel Injectors, and Codes Hayes9000 6.0L Power Stroke Diesel 26 01-11-2017 08:15 PM
Totally lost now!!! tcjhkbjt 6.0L Power Stroke Diesel 31 03-23-2015 09:33 PM
p0263 and p0275 96_F250_Deezal 6.0L Power Stroke Diesel 3 01-27-2015 10:31 PM
2003 F-350 6.0 Contribution/Balance Fault Frankenstein2003 6.0L Power Stroke Diesel 4 03-13-2012 09:39 AM
Codes P0272, P0275, and P0278 Hayes9000 1999 to 2016 Super Duty 4 06-02-2010 07:36 PM
Tags
2006, 250, 60l, 6mm, balance, code, codes, cylinders, f250, ford, injector, issue, p0263, p2269, throwing, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
