Well no responses so far but that's cool because I figured it out all by myself. So I willl answer the questions in case someone else has this problem and needs advice. The part that was next to the crank pulley is the crankshaft position sensor. The belt, upon breaking, smacked the wires clean off. This is the reason it wouldn't start. The reason the idler pulley broke was in my best guess, just a coincidence. The bearings were bad and it was an original part. The car can start without the belt but not recommended since the alt. and other parts run off of the belt. That was easy. My advice to anyone that needs an answer quicker....post it under the correct subject and do the research yourself.
