Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-15-2009, 06:23 PM
spdmpo's Avatar
spdmpo spdmpo is offline
2000 Ford F-350
spdmpo has a very good reputation on FTE. spdmpo has a very good reputation on FTE. spdmpo has a very good reputation on FTE.
Dieselsite overboost relief valve didn't work last pull
I pulled my 34' goose loaded to 15K gross (2 heavy Jeeps) this weekend on my wheeling trip. I was finally armed with the ATS housing, a JWVB, Tru-Cool, and a Dieselsite boost relief valve for good measure. On the way home up a long grade I was tugging right along and then it was time to downshift. Boost came up and all was good, but then I see the SES light. Darn it! It goes off a few more miles down the road and I realize that is the overboost code again. I plugged the SCT scanner in and confirm it was. Then I check the max reading on the boost gauge and it was 25 psi.
I thought that whole point of this valve was to prevent this silly light. What gives? Is this one of those POS snake oil parts? I mean it was only $45, but still I'm not happy about wasting money.
And BTW, the ATS housing is the shizzle, as is the JWVB. Very nice. Now for that 4" exhaust to help with the EGTs a little hopefully. I had to back out of it one time, sucks cause I was modocking right up the grade.
__________________
Keith
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
'00 F350 CC LB 4x4 PSD - DP Live Tuning, ATS housing, 6.0 IC, Ford AIS, 4" Magnaflow, BD X-Monitor, Front leveling kit, Firestone air bags, JWVB, FRx, HPX, coolant filter, Hutch mod, ITP in-tank, Carter lift pump, CCV, Tru-cool, AIH delete, OBA, cold a/c
  #2 (permalink)
Old 06-15-2009, 06:32 PM
big poppa's Avatar
big poppa big poppa is online now
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
I was under the impression thats what it was for. Subsribing because I need one..
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Roadside Help Network
  #3 (permalink)
4inchlovin's Avatar
4inchlovin 4inchlovin is offline
2001 Ford F-250
4inchlovin is a splendid one to behold 4inchlovin is a splendid one to behold 4inchlovin is a splendid one to behold 4inchlovin is a splendid one to behold 4inchlovin is a splendid one to behold 4inchlovin is a splendid one to behold 4inchlovin is a splendid one to behold
Are you talking about an over boost annihilator?
__________________
Nolan
2001*F250*Ext.Cab*LB*4x4*6spd
4"turbo back exhaust, 6637w/custom Pete cover, Gooseneck hitch,
Cobra148GTL w/102" whip
PAA #64
  #4 (permalink)
Old 06-15-2009, 06:37 PM
Centauro97's Avatar
Centauro97 Centauro97 is offline
Centauro97 is starting off with a positive reputation.
That thing is so simple it should work if it's gonna work.
Have you pulled on the little ring to make sure the valve isn't stuck?
  #5 (permalink)
Old 06-15-2009, 06:44 PM
spdmpo's Avatar
2000 Ford F-350
Quote:
Yes I am, Same thing, they call it a different name I guess.
Yes I did, it feels like it should be working to me, there's resistance when I pull it. And it's brand new, so it isn't gummed up or anything.
__________________
Keith
  #6 (permalink)
Old 06-15-2009, 06:50 PM
big poppa's Avatar
Hopefully some other DS overboost relief valve users chime in on there experiences with it.
__________________
  #7 (permalink)
Old 06-15-2009, 06:55 PM
spdmpo's Avatar
2000 Ford F-350
Yes, that would be nice to hear from them.
Until then, and until I can get a hold of DS, I guess I'll get out the regulator and air hose and see if I can get it to do what it should be doing.
__________________
Keith
  #8 (permalink)
Old 06-15-2009, 07:27 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
you feelin' lucky PUNK?
indyF-350psd has a good reputation on FTE. indyF-350psd has a good reputation on FTE.
never had a problem with mine. it does say to every once in a while spray the little valve thing with some WD or other lube. you have to pull the little thing up and spray it. ive been boosting up to about 30 lbs on my stock turbo (i know) and never had the boost code set off..........
  #9 (permalink)
Old 06-15-2009, 09:24 PM
Izzy351's Avatar
Izzy351 Izzy351 is online now
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
So does that actually let air out? Wouldn't that be a bit of a boost leak? The regulator type like the ITP doesn't... Here's a pic of mine (far left of the pic):
__________________
  #10 (permalink)
Old 06-15-2009, 09:35 PM
Trouble1263's Avatar
Trouble1263 Trouble1263 is offline
Trouble1263 is starting off with a positive reputation.
I ordered the "codes" tunes on my DP..Have yet to set off an overboost..Just another option.
__________________
Not much to see here folks,,move along!!
Duane
2001 F250 CC 172" 4x4 3.73 Lariat
6637, CCV, Isspro Gauges,Bilsteins,Mile Marker Hubs,Firestones,
4" Magnaflow SS,RDP-WW&HPX &GPR LED ,Foil Delete ,DP -NS/DT/S/80E/40T/Decel/60T/120R
  #11 (permalink)
Old 06-15-2009, 09:38 PM
yeah its kind of a blow of type boost code eliminator. it has a small hole on the outlet side that will only let the computer see about 19-20 lbs and the rest gets let out the valve.
on the no code tunes does the truck still defuel and not throw a code or does it keep the truck from defueling as well......
  #12 (permalink)
Old 06-15-2009, 09:40 PM
spdmpo's Avatar
2000 Ford F-350
Quote:
Kinda sorta it is I guess. I was concerned about that and read up between the two styles. The DS one and the ITP regulator one. What I came up with in my own little head was the DS 'leak' was very insignificant and not a problem. But it was supposedly more accurate. The regulator type regulates in a progressive manner meaning at the lower pressures it regulates too much. But right now I'm wondering if I should have went that route.
Yeah, I could always email Jody and pay a few $ for the codes tunes; but I didn't want to unless necessary.
__________________
Keith
  #13 (permalink)
Old 06-15-2009, 09:41 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
There are two types one is just a preset pressure relief valve it lets air out at a certain pressure. The other that is more commonly used is just a regulator that is used to limit the psi that the MAP will see so that you don;t get an overboost code and defuel
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #14 (permalink)
Old 06-16-2009, 01:43 AM
big poppa's Avatar
Seem's like the DS regulator is in sense is like a wastegate of sorts, not a boost fooler, thats what I figure??
__________________
  #15 (permalink)
Old 06-16-2009, 06:17 AM
megawatt00's Avatar
Quote:
That is exactly how it works Mike.
From the DI site:
Boost Pressure Relief Valve
With this device installed between the intake manifold and the MAP sensor, boost pressures above 24PSI will be released so that the SES light is not set and the MAP sensor does not command the PCM to go in to a defueling mode. This is a mechanical device and as such, allows the SES light to function as designed.
__________________
Jim
2001 F350 4X4 DRW
PAA # 14
Tags
60 , 73 , blown , boost , dieselsite , ford , hose , overboost , powerstroke , pressure , relief , reviews , valve , valves , work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
