My Reverse Sensing System just started to give me a solid tone when in reverse. The cut-out switch on the dash still works correctly. I cleand the RSS sensors - did not fix problem. Does anyone know which fuse controls the system (2004 diesel) so I can check it? Any other suggestions?
Either one of the sensors is bad, or it is the module itself. Like I said, you either need the Ford scan tool, IDS, or a good aftermarket one like Snap on Modis or a OTC Genisys to "talk" to the RSS module. The cheap Auto Zone type will not work.
