5.4 motor issues in Lincoln Blackwood - Ford Truck Enthusiasts Forums
Old 06-15-2009, 10:50 AM
donarmstrong58 donarmstrong58 is offline
donarmstrong58 is starting off with a positive reputation.
I am having trouble isolating the problem with this motor, I was running down the interstate got on it a little bit and she stalled. I changed all the coil packs and placed new plugs. Which was long overdue; based on the code reading random misfire cylinders, the cats got hot so i replaced them on Saturday. Still nothing. Cleared codes and now truck starts better runs like its missing and the cats on the passenger side get hot quick , so I shut her down....but no codes came up...talked to Ford and they indicated a EGR problem would cause no computer codes...........looking for an answer .....can anyone help.....??
Old 06-15-2009, 02:05 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
The actual codes could help.
Old 06-16-2009, 08:59 AM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
Start by changing the fuel filter.
Old 08-04-2014, 06:51 PM
bobalew bobalew is offline
bobalew is starting off with a positive reputation.
Bad Bank fire codes? One bad Cyl, or Cyl misfire?
Look at the top of your Air plenum where the EGR valve & Vacuum advance valve connects to the Intake manifold, Right at the top, Under the windshield wipers. Ther's a Right angle rubber connector boot that attaches directly to that vacuum system. There's your leak! Find a silicone rubber Spark plug boot & replace it with that. Trust me, it's weird, but it fits. Otherwise, get few varied diameters of Hoses & hose clamps & replace it with that. This error drove me nuts until it flat out failed. The Alcohol from your windshield washing fluid, deteriorates the rubber on this part, creating a slowly increasing vacuum leak. and Varous BS error codes. This miay also explain the extra oxygen in yopur exhaust, causing calalytic converter overheating. ( SDo that what that HOT smell was...). Any way sorry to let you know tyou spent wat y too much money on fixing it, My fix cost me $8.57 at the local NAPA parts store, & would have been free, if I'd have thought of the spark plug boot fix...
REgards, Bobalew
No power and lots of stumbling Conanski 1968-2013 Full Size Vans 12 06-13-2016 04:38 PM
03 f-250 5.4 drivability issue Bueller 1999 to 2016 Super Duty 7 03-07-2016 08:50 PM
Truck 302 to Mustang 302 H.O injector ?'s makingaZJ 1987 - 1996 F150 & Larger F-Series Trucks 13 02-19-2013 12:33 PM
Catalytic converter glowing red Fairlane62 1997 - 2003 F150 9 04-04-2007 12:35 AM
More 1987 Crown Vic 5.0 electrical/idle problems ceetwarrior 1987 - 1996 F150 & Larger F-Series Trucks 12 04-25-2005 11:35 PM
Tags
2002, 2009, 54, blackwood, cylinder, ford, forum, issues, linco, lincoln, misfire, motor, problems, starting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
