Hi new to this site in 09,I have a 2001 F250 4x4 cew cab was wondering if there is ANYONE out there that knows if it is possible to adjust the doors,they rattle when I cross over little bumps like a washboard in the road,anyone????????.Thanks
Figure out where the rattle is coming from. You might also ask up in the Super Duty section here. Many people tighten up the door seals by removing the weatherstripping and sliding a foam type or silicone backer rod inside the door seal. Makes the door a little harder to shut, but it should tighten things up a bit.
they are rattleing at the door latches.The weather stripping Idea sounds good.might use that as a last resort,I would be affraid to not get seal back good enough and then I would have a leaking issue also.Thank you for the idea Chris
