fuel heater fix directions!!!!! w/pics - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 09-23-2013, 11:17 AM
MackGuy MackGuy is offline
MackGuy is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by The_Josh_Bear View Post
Hey guys,
I've been leaking fuel through the fuel heater since winter, finally got around to fixing it. It definitely helps to cause air-intrusion when leaking.
Anyway, as many guys as bought the o-rings from NAPA, nobody put down a part number...
Larger O-ring= NAPA AUTO PARTS
Smaller O-ring= NAPA AUTO PARTS
Keep in mind that the pictures are representative images, and look NOTHING like the o-rings you'll get.
(And in order to get these links, I had to go to the dumb NAPA, measure the o-rings with a caliper, and then buy them with the part numbers on the drawers they are in. SO STUPID! You can't search napaonline.com for o-rings! I hate their site, it's one of the worst business sites I've ever been to.)
As for Orielly's, they can't even order them into the stores. They have them online, sure, but it'll cost you $10 TO SHIP 2 O-RINGS.
Anywho, these fit great and I'm now 2 days leak-free. Truck starts better too.
Oh and pay attention to the part where you separate the male contact lead from the plastic housing(picture #5 from RupeJosh). I didn't realize there was a barb on it, and ended up breaking that lead. Which is brass so I couldn't solder it... if anyone has one of those in working order I need one! Thanks!
-Joshua
Thanks for that link!
For my 1990 will I have the single o-ring or 2 o rings?
Thanks!
  #62
Old 09-30-2013, 09:16 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Quote:
I fixed one with a 1/2in npt tap and brass pipe plug.
Fixed mine this weekend using this method - thanks for the tip! I live in Central Texas so not a big loss deleting the heater.
  #63
Old 12-04-2013, 02:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
'93 f-450
the heater elements o-ring was ok once i inspected it as i had figured,but the issue with mine was,that the actual inside of the e-connector was filling up full of fuel and flowing over from there,so the only way to fix that would be with a new heater element or simply plug the hole.at the cost of those oem heaters,i chose to tap and plug the hole with jb welded threads for a nice permanent leak free fix.
  #64
Old 12-04-2013, 07:48 PM
dsltech83's Avatar
dsltech83 dsltech83 is offline
dsltech83 is starting off with a positive reputation.
Keep an eye on it if you used a steel plug. The one I used first vibrated loose multiple times before I chucked it and replaced with brass. No leak since.
  #65
Old 01-12-2014, 09:49 PM
rupejosh's Avatar
rupejosh rupejosh is offline
rupejosh has a very good reputation on FTE.rupejosh has a very good reputation on FTE.rupejosh has a very good reputation on FTE.
i had a few emails this week about the fuel heater fix so im bumping this back to the top
  #66
Old 01-23-2014, 03:59 PM
nw_ia_guy nw_ia_guy is offline
nw_ia_guy is starting off with a positive reputation.
I have a 1990 7.3 in my F250 and it has had this problem. I went to the local farm store for O-rings & they didn't have the Vitons but I was able to size the ones that I needed. My type uses 2 o-rings, not one as some.
<table border="1" width="80%"><tbody><tr><td align="middle">1/2"</td><td align="middle"> 5/8"</td><td align="middle"> 1/16"<td align="middle"></td></tr></tbody></table>014's
<table border="1" width="80%"><tbody><tr><td align="middle">5/8"</td><td align="middle"> 3/4"</td><td align="middle"> 1/16"</td></tr></tbody></table>016's
I emailed these guys & they said that for diesel the best bet is these.They work perfect:
You get 50 of each for about $15 total. If those listing are gone, search for sellers: "Penske40"
This is not difficlt or a time consuming job. I did have a little trouble getting the electrical spade to push down through the plastic to get to the inside o-ring. Look straight doun on it & bend the little tab so it is inline with the hole. I suggest you take a magnifying glass & look at the tab BEFORE you start to mess with it. You'll see what you need to do.
Watch that video above about turning the filter assemble upside down & rebolting to remove that center bushing!!! Excellent idea! Keep it stock for a few bucks & a little time. I would go to the Hastings FF1039-SP filters tough & have the Drain Valve & Sensor Port right in the filter. Do away with that bottom plate.
  #67
Old 01-23-2014, 04:38 PM
jas88's Avatar
Glad I used brass on mine, then.
  #68
Old 01-23-2014, 06:25 PM
Quote:
i used jbweld on the threads.i doubt she'll ever go anywhere,but will do.
  #69
Old 01-24-2014, 08:58 PM
kla94's Avatar
kla94 kla94 is offline
kla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputation
I fixed mine a little while back. My locals didn't have any o-rings that worked so I took some o-ring material and made one that fit good. So far so good. Having fuel issues, but the heater is dry!
  #70
Old 03-06-2014, 02:39 PM
waterdog40's Avatar
waterdog40 waterdog40 is offline
waterdog40 is starting off with a positive reputation.
Thanks AKAMACGYVER!!!!
I am trying it as we speak 3 times the charm right great idea for sure... AM in ur debt sir... thanks again arron
  #71
Old 03-06-2014, 10:19 PM
akamacgyver's Avatar
akamacgyver akamacgyver is offline
Clueless spectator!
akamacgyver has a good reputation on FTE.akamacgyver has a good reputation on FTE.
You are welcome kind sir! I know how you feel. I did my first one in a trailer park in Oregon with no bench vise or large sockets. It was a bear, but after I figured out a few tricks, I can do one in about 30 minutes! I like to keep my trucks as original as possible, so plugging it was a last option for me.
Mac.
  #72
Old 03-07-2014, 02:01 AM
waterdog40's Avatar
THANKS AGAIN!!!
Quote:
Mac.
I like to keep it original also to a point....lol... plus the negative. temps up north here wanted heater also... I tried first time with vise no joy second time as shown in video came off replaced o ring and no leak!!!!! Next is down pipe gauges and 3" exhaust ... So happy...lol.
  #73
Old 04-01-2014, 02:35 PM
waterdog40's Avatar
So I have been so busy here lately have not been able to get on here... but anyway the fuel leak at the filter under the plug we had the pictures of ect ect... well I have got it fixed so far the O ring I put in is working awesome once again thanks to u pros here in the diesel department a little time and $1.50 O ring fixed mney saved... Thanks again from arron
  #74
Old 08-29-2014, 07:49 PM
jamesj2 jamesj2 is offline
jamesj2 is starting off with a positive reputation.
Hello,
I'm a new owner to a 1988 7.3 diesel and have this issue. Does anyone know where I can get the black housing that connects to the fuel heater (spade)? Do I have to purchase the whole harness? Thank you-
  #75
Old 08-30-2014, 06:15 AM
fuzzy1626's Avatar
fuzzy1626 fuzzy1626 is offline
fuzzy1626 is gaining momentum as a positive member of FTE.fuzzy1626 is gaining momentum as a positive member of FTE.
Salvage yard. If you don't live in an area with extreme cold you could tap the hole and put in a pipe plug.
NSRA Northeast Nationals Show Pictures GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 10-10-2012 10:46 AM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 01:02 PM
Dual exhaust pics Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-12-2009 09:50 AM
mother nature 1 us 0 460429_freak Missouri Chapter 3 05-14-2009 02:56 PM
My 2009 F-150 Platinum morgan867 2009 - 2014 F150 56 01-01-2009 03:59 PM
Tags
1993, 2001, 73, diesel, dripping, engine, f250, f350, fix, ford, fuel, header, heater, inline, oring, pics, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
