Zf 5 Fluid
Mercon Auto Trans Fluid
I use Mercon automatic Transmission Fluid.
I was told by the Ford rep back in 1991 when I purchased my truck that the ZF-5 has such close tollerances that ATF was used because gear lube would be squished out of the gears leaving them dry. He also said that the ATF should be changed regulary because any dirt accumulation would be ground into the gears causing big problems.
I don't know how correct he was, but I change both my transmission (ZF-5) and transfer case every 50,000 miles and have never had a problem, 260,000 miles and still going strong. (note- For about 10 years I used to haul several 2-ton loads each week and still carry a 3,500 truck camper 5-6 times a year.)
ATF is the oil too use.... I have 350,000k on my truck.
But with the notorious noise the ZF makes... specially with the SMF conversion... some have used synthetic engine oil (10w30 I think), just to try too quiet it down a bit... mine sounds very similar to a concrete mixer in the first couple of gears...lol. I think I'm going to try it out next oil change and see if it makes a difference.
These tranny's were designed for atf and using any fluid other than that would be a gamble IMHO... People have used synthetic engine oil and I will surly give it a try but I know it's at my own risk... I'm just willing to take it cause I can't stand the noise and in reality my tranny prolly wont last too much longer anyhow with the miles it has....
So my advice would be to use atf... or upgrade to synthetic atf... if you think your tranny's too loud and you want to gamble then use a thicker synthetic engine oil, it has been done... but I doubt some one will recommend it solid flywheel conversion or not.
hope that helps....
mark460
16
07-07-2017 10:53 AM
Pickupmanx2
02-16-2010 11:07 AM
tsheriff
08-15-2003 05:32 PM
