Synthetic lube for trans, transfer case, and, both differential, in 1989 F350
Old 02-17-2002, 02:59 AM
rick1989F350's Avatar
rick1989F350
rick1989F350 is offline
Hello,
I'm needing some guidance. I would like to use the best lube in both my differentials, ZF 5-speed transmission, and, transfer case.
I need recomendations from the people who know. What should I use as standard replacements of these lubricants? Also, where is the best place to go for larger fuel tanks?
Thank you for your time,
Rick Fine
Old 02-20-2002, 10:08 PM
TonyG's Avatar
TonyG
TonyG is offline
I used Valvoline synthetic in my ZF-5 and it made a big difference in shifting ease, especially in cold weather. I have about 80,000 and the garageman says it looks like new. But I'll be draining and replacing it when I change engine. I've heard that you should run the same fluid in your transfer case that you run in your transmission because synthetic and mineral base gear oils don't mix. If the transfer case seal go'es bad, you might ruin both transmission and transfer . But this is heresay and I havn't heard anything official along those lines. I think you'd have to split the transfer case and also remove the rear end cover to properly clean those areas to run sythetic, but it might be worthwhile. Not a plug for Valvoline, but a definate good experience with synthetics.
Tony
Old 02-20-2002, 11:50 PM
Art's Avatar
Art
Art is offline
piersol
12-25-2009 09:49 AM
richardfine
20
04-10-2009 04:31 PM
kev100
03-31-2003 02:19 PM
Steeve
08-30-2002 09:51 AM
rick
01-10-2000 10:14 AM
Quick Reply: Synthetic lube for trans, transfer case, and, both differential, in 1989 F350
