Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-20-2009, 12:19 AM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
2006 Ford F-250
Robs06SuperDuty is starting off with a positive reputation.
yes, thats what im running.
__________________
Robby
06 F250 5.4L SC LB 4x4
Plow Package, Leveling Kit, Bilstein HD's
Cooper Discov STT 35x12.50x18's
Rough Country Dual Stabilizer Kit
K&N Drop in and Flowmaster Super 40
  #17 (permalink)
Old 06-20-2009, 09:23 AM
66 BADBOY 66 BADBOY is offline
66 BADBOY is starting off with a positive reputation.
Quote:
Rob,
I looked at your gallery and I was wondering if you had a sideshot picture showing the overall stance of the truck from bumper to bumper?
Thanks!!
__________________
My motto on life: Don't EVER look back, just flush.
  #18 (permalink)
Old 06-20-2009, 09:28 AM
not sure if shockwarehouse.com is still having there buy 3 get one free deal on Bilstein HD's.
Nope. Just looked. Right now its buy 4 and get 10% off.
__________________
  #19 (permalink)
Old 06-20-2009, 10:09 AM
2006 Ford F-250
No I dont, atleast not yet anyway. If it clears up today ill take one and post it up.
__________________
Robby
  #20 (permalink)
Old 06-20-2009, 10:11 AM
Hey thanks!!
Do you have any idea on this:
Link
__________________
  #21 (permalink)
Old 06-20-2009, 11:53 AM
2006 Ford F-250
here ya go.
__________________
Robby
  #22 (permalink)
Old 06-20-2009, 03:36 PM
VERY NICE MAN!!!
Looks like that leveling kit works really well.
Thanks for posting that pic!!!
__________________
  #23 (permalink)
Old 06-20-2009, 09:41 PM
cdrmotorsports's Avatar
cdrmotorsports cdrmotorsports is offline
cdrmotorsports is gaining momentum as a positive member of FTE. cdrmotorsports is gaining momentum as a positive member of FTE.
That is exactly the look that I want. Thanks for the pic Rob. What's the best overall leveling kit out there?
__________________
2005 Ford F350 Crew Cab King Ranch FX4 4X4 6.0L PowerStroke V8 Turbo Diesel
4" MBRP 304 stainless dual exhaust. No muffler. 5" stainless tips.
My gallery: http://www.ford-trucks.com/user_gall...?userid=289268
  #24 (permalink)
Old 06-21-2009, 01:02 AM
2006 Ford F-250
some ppl say the front is higher than the rear but they are dead nuts the same height. as for best leveling kit I dont know, I have the Skyjacker 1" Kit and the only thing I dont like about it is the spacers are Red, I prepped and painted them but its chipped off in spots due to the compression.
CDR your prolly gonna want to go with a 2" or 2.5" kit which skyjacker makes also. Your prolly going to need a track bar relocating bracket also.
__________________
Robby
  #25 (permalink)
Old 06-21-2009, 01:08 AM
2006 Ford F-250
heres what the spacers look like.
__________________
Robby
  #26 (permalink)
Old 06-21-2009, 08:14 AM
Is there a reason he needs the track bar relocation bracket? Not doubting you, but I haven't heard of people going 2.5" needing that. I'm curious because I will be doing the same height lift in the front.
I was thinking about the Truxxx kit. 2.5" block in front, 1.5" blocks in back. I figured that would be the way to go because I will also have the plow prep springs, which might make the front sit a tad higher because the springs won't compress as much.
__________________
  #27 (permalink)
Old 06-21-2009, 09:19 AM
1 Cajun 1 Cajun is offline
1 Cajun is starting off with a positive reputation.
Tire plus size
I installed the 285 75 18 Toyo Open Country's without having to add a leveling kit. The only thing I had to do for clearance was to remove a small rubber spacer from my front Ford mudflaps. Everything looks good, rides good, and lots of clearance turn to turn. And remember theses tires are load rated compared to a lot of others which aren't.
  #28 (permalink)
Old 06-21-2009, 09:58 AM
2006 Ford F-250
it just depends on how much the axle moves over after the lift is installed. You dont NEED one but if you want the front axle to be centered then you'd have to get a reloc. bracket or adjustable trac bar.
do you have a 350 or a 250? with the plow package you'll have a helper spring(overload leaf) in the rear. if you have a 250 just swamp in a F350 block and u bolts. if you have a 350 i'd try and find an AAL in the size you need, instead of stacking blocks. just my .02
__________________
Robby
  #29 (permalink)
Old 06-21-2009, 03:27 PM
78bigbronco's Avatar
78bigbronco 78bigbronco is offline
78bigbronco is starting off with a positive reputation.
His sig says '05 F350
__________________
09 F-350 V10 4x4 6spd CC/8' ordered 5/26/09 delivered 7/6/09
99 F-150 4x4 Reg/Short bed
78 Big Bronco 4x4 (a work in progress)
84 Tbird (351W project still in dry dock)
  #30 (permalink)
Old 06-21-2009, 04:42 PM
CoastieMK's Avatar
CoastieMK CoastieMK is offline
CoastieMK is starting off with a positive reputation.
Has anyone put on the Skyjacker 2" kit that replaces the front springs and adds a leaf in the rear instead of adding the spacer? I was thinking about getting it.
Tags
35 , big , f150 , f250 , f350 , ford , forums , king , kit , leveled , leveling , ranch , reviews , stock , superduty , tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
