Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-14-2009, 07:27 PM
yosemitesamiam yosemitesamiam is offline
yosemitesamiam is starting off with a positive reputation.
Poor Mileage, all of a sudden, worse than normal!
Hey all...I know it has all been heard before. Also posting this in Exped forum. Just some background here:
1999 Expedition XLT, 4x4 5.4. 3.73 rear axle, etc etc. I know, I'm already set up for failure here....however that said, I was pretty used to seeing 13.5-14 town, and 16.5-17 highway. Now, no matter where we go, we get 10.3. City/highway, doesn't matter....10.3.
I'm not getting codes, I'm not running rough. I am noticing heavier than normal black stuff accumulating at the tailpipe...of course because it is running rich.
My first instinct was to check the Coolant Temp Sensor....it is the only thing I can think of that besides stuck open or shorted, will not throw a code, but will make the engine run as if it were cold all the time. Then I discovered that I don't have a Coolant Temp Sensor...that seems to be Navigator only this year this engine.
Anyway, any other guesses, other than someone siphoning the tank, or a flat out fuel leak that I can check for? Again, running great...just sucking way more than normal fuel.
Thanks guys.
Sam
__________________
99 Exped XLT 4x4 5.4L
Frisbeetarianism is the belief that when you die, your soul goes up on the roof and gets stuck.
  #2 (permalink)
Old 06-15-2009, 08:44 AM
Fishin76 Fishin76 is offline
Fishin76 is starting off with a positive reputation.
Air temperature Sensor will do the same thing.
__________________
These are not the Droids you are looking for.....
Current vehicles:
98 Contour 2.0L auto, my new DD 49K 30mpg
2009 Dodge Grand Caravan SXT 3.8L 6sp auto
1986 F250XL Diesel RC LB 4x4 T19 4spd 4.10's?
  #3 (permalink)
Old 06-15-2009, 09:13 AM
torkum's Avatar
torkum torkum is offline
1997-2003 Restoration
torkum is gaining momentum as a positive member of FTE.
Try cleaning your MAF with a approved cleaner. A little dirt on the wires could cause a false reading.
__________________
2003 SUPERCREW 4X4
Tim
My PICS:
http://www.supermotors.net/registry/18031
  #4 (permalink)
Old 06-15-2009, 09:48 AM
Yeah, tried the MAF. Its been hosed with MAF cleaner. LOL. I have not looked at the Air Temp Sensor however...any ways to check it via volt meter, etc?
Also in regards to oil consumption. Now using about a quart every 1,000-1,200 miles or so. Checked the easiest thing, PCV...it is fine darn it. Have lots of pooled oil down in the gully below the intake.
__________________
  #5 (permalink)
Old 06-15-2009, 10:51 AM
wb6anp wb6anp is offline
wb6anp is starting off with a positive reputation.
Check the torque of your rocker cover bolts, loose bolt could account for the pooled oil.
__________________
2009 F-150 Supercrew Platinum in Dark Blue Pearl
2008 Escape Hybrid
2008 Tiffin Allegro 32BA Motorhome on a Ford F-53 6.8l V10
http://community.webshots.com/user/wb6anp
  #6 (permalink)
Old 06-15-2009, 08:33 PM
Yeah, there is a way to test, but I don't know what it is. The air temp sensor is cheap enough, I say just replace it. Thats what I would do. As I grow older, I'm finding that time is more expensive than parts, (most of the time), And I have less and less of it to spend diagnosing cars.
__________________
Current vehicles:
  #7 (permalink)
Old 06-24-2009, 02:20 AM
JJ98 JJ98 is offline
1998 Ford F-150
JJ98 is starting off with a positive reputation.
what the miles on the vehical at might be time for 02 sensers or the or the plugs could be bad by miles to many little what if
  #8 (permalink)
Old 06-24-2009, 02:26 AM
Quote:
Wow dude! All over the place there, but I think I get ya. bad O2 would trip codes though man...
__________________
  #9 (permalink)
Old 09-03-2009, 09:05 AM
loudford loudford is offline
loudford is starting off with a positive reputation.
I had a similiar problem with my 03 5.4, poor gas no codes and only 60K. Finally threw a code for cylndr and I replaced all the plugs. They didn't look that bad but it was enough, after I replaced all is good. Mileage is up and throttle response is much better. Depending on you mileage it may be time? Before replacing the plugs I changed air/fuel/pcv valve that didn't help much.
GL
Lou
__________________
2003 F250 4X4 SD extended cab XLT 5.4L 3.73LS
  #10 (permalink)
Old 09-03-2009, 10:02 AM
Quote:
GL
Lou
Hey, thanks man! That is kinda what we deducted as well...just don't have the time right now to handle it. No codes by the way, no pendings, no nothin! Scanned it using my dad's equipment...shop grade scan tool. Oye Vey I say! Plugs she will be!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
