can i put old oil,atf and gear lube in my 6.9?
don't know all the details but...
You filter waste veggie oil and then use one of your tanks for veggie and one for petro diesel. The veggie oil needs a heater to warm it up and make it thinner and easier to burn/pump.
You start the truck on petro diesel, then switch tanks over to veggie once it's warm, then you need to switch back to petro diesel the last couple miles to flush out the veggie oil.
There are some other things you need... but that's the basics. You can buy kits to do it.
Try this sub-forum's sponser: http://www.vegistroke.com/
They have the best system IMMHO...............
MonatheGrona94
Oil & Lubrication
06-06-2007 09:41 AM
BCO2JCO
04-09-2007 09:55 PM
mcbob
12-22-2003 12:23 PM
