Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-14-2009, 06:51 PM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
can i put old oil,atf and gear lube in my 6.9?
Can i put old motor oil,atf ,frying oil and gear lube in my 6.9? If so, how do
I filter it?Do I need to mix it with fuel, or can I run it strait?
sorry but I am a to this hole alternative diesel fuel thing.
  #2 (permalink)
Old 06-23-2009, 11:00 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is online now
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
ATF yes, fry oil needs to be filtered and heated and would need a WVO conversion... I wouldn't put motor oil or gear lube in it
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #3 (permalink)
Old 06-24-2009, 09:52 AM
bill11012's Avatar
How do i do the WVO conversion?
__________________
my V10 will out pull your PSD any day of the week.
Quote:
Originally Posted by Jmeyer1990
... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
  #4 (permalink)
Old 06-24-2009, 10:02 AM
1995 Ford F-350
My Garage
don't know all the details but...
You filter waste veggie oil and then use one of your tanks for veggie and one for petro diesel. The veggie oil needs a heater to warm it up and make it thinner and easier to burn/pump.
You start the truck on petro diesel, then switch tanks over to veggie once it's warm, then you need to switch back to petro diesel the last couple miles to flush out the veggie oil.
There are some other things you need... but that's the basics. You can buy kits to do it.
__________________
  #5 (permalink)
Old 06-24-2009, 11:29 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
Try this sub-forum's sponser: http://www.vegistroke.com/
They have the best system IMMHO...............
__________________
FABMANDELUX.
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #6 (permalink)
Old 06-24-2009, 11:35 AM
bill11012's Avatar
I will try to get details there.
__________________
  #7 (permalink)
Old 06-26-2009, 08:13 AM
kirkharrod kirkharrod is offline
kirkharrod is starting off with a positive reputation.
Greasin' is not for everyone.
__________________
2002 F-250 Super Cab, 225,000 miles, 25,000 on WVO; Greasecar conversion, 140 gal grease tank, 30 plate heat exchanger, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, CAT ELC, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. ZERO grease related problems.
Tags
69 , 73 , atf , deisel , diesal , diesel , ford , gear , idi , kit , lost , lube , mix , oil , pressure , put , veggie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
