Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-14-2009, 05:04 PM
Paint_burner Paint_burner is offline
Paint_burner is starting off with a positive reputation.
Mpg 7.5l 460
I am looking at buying a 1996 F250 with the 7.5L 460 engine in it. I was wondering what kind of mileage I could expect to get.
Thanks,
  #2 (permalink)
Old 06-14-2009, 08:10 PM
bill11012's Avatar
bill11012 bill11012 is online now
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
mine gets 5 city 7 highway. It is worn out, and has pulling gears.
what motor and trans does it have?
__________________
my V10 will out pull your PSD any day of the week.
Quote:
Originally Posted by Jmeyer1990
... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
  #3 (permalink)
Old 06-14-2009, 09:54 PM
I believe the original. I will ask to make sure though. It does have headers, cold air intake, a 4'' suppension lift, 18'' wheels, and 36'' tires though
  #4 (permalink)
Old 06-14-2009, 10:15 PM
bill11012's Avatar
ok, what gears and trany?
A 96 will have an OD. so depending on gear and trans type, I would say 6-12. If you plan to do a lot of towing you my want to go with a 99- NBS
truck with the V10. I have both the 415 V10 and 460 big block v8, and the 460 just does not compare. My 460 is a 4bbl, so yours may be way better.
__________________
  #5 (permalink)
Old 06-14-2009, 10:28 PM
Ok thats kind of what I was guessing. I'm not going to be pulling with it mainly off roading and plowing. The guy selling it said he got 12-14 mpg and I just wanted to check to see if that was close or not.
  #6 (permalink)
Old 06-14-2009, 10:35 PM
bill11012's Avatar
my v10 gets 14- 15 highway, so that may not be far off.
is it auto or stick shift?
__________________
  #7 (permalink)
Old 06-14-2009, 10:42 PM
its an auto
  #8 (permalink)
Old 06-14-2009, 11:33 PM
bill11012's Avatar
ok, than it has a E4OD.you should get about the mpg he says highway, 6-12 city, but that is just a guestament. If you post in the 87-96 forum, and give all the trucks specs, you should get a better idea.
__________________
  #9 (permalink)
Old 06-14-2009, 11:58 PM
copracer288 copracer288 is offline
copracer288 is starting off with a positive reputation.
I think I get gallons per mile.
  #10 (permalink)
Old 06-15-2009, 12:15 AM
OldRacerGuy's Avatar
OldRacerGuy OldRacerGuy is offline
OldRacerGuy is starting off with a positive reputation.
My 92 gets 10-11 at 70mph, 7-8 around town. 31" tires, all stock except for a 3" catback exhaust and a fresh trans. New headers and a cam/lifter kit are waiting in the garage, I'm hoping to get better mpg's when it's all done..
__________________
92 F350 4x4 crewcab E4OD 460
  #11 (permalink)
Old 06-15-2009, 12:27 AM
jeremy2008's Avatar
jeremy2008 jeremy2008 is offline
jeremy2008 is starting off with a positive reputation.
wow you guys get good mpg with a 460 mine is **** what did you guys do to yours i have a 93 f-250 460 e40d what gears do your run in your diffs. 33" tires.
  #12 (permalink)
Old 06-15-2009, 05:23 PM
jim henderson jim henderson is offline
jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE.
I have a 94 F250 Supercab longbed with fiberglass shell, 4X4, E4OD, 4.10 gears. Your mileage will vary a lot depending on options, gearing etc.
I typically get about 10-11mpg for mixed around town with freeway driving, IF I go about 50-60mph on the freeways. If I go over 70(Almost required around here) it drops to maybe 9mpg. Almost doesn't make a difference how I drive as long as I am not stuck in stop and go or going something like 80mph. Best I have ever seen is maybe 13mpg downhill on a tail wind drafting a semi. Speed appears to be the mileage killer with my rig, lots of wind drag.
With my 8,000# trailer I get something like 8-9mpg on steady flat land driving at about 60mph. Worst I have seen is around 5-6mpg hauling the trailer up long steep slopes like the Grapevine in Calif.
I use synthetic lubricants all around but my log book doesn't show me any mileage improvement that I can clearly point to.
Just my experience,
Jim Henderson
  #13 (permalink)
Old 06-16-2009, 10:09 PM
Ok, that gives me a better idea. I want something for a fun truck, some off roading and such, but also need to get something I can plow with in the winter. I love the truck, but almost wonder if I need to look for something with the 5.8L. How big of a difference do you think there really is? Both gas wise, and power for what I want to do with it
  #14 (permalink)
Old 06-16-2009, 10:56 PM
bill11012's Avatar
the 351 will give you about 1 - 2 mpg more, for a lot less power.
If you want better mpg and power than a 460, get a NBS ( 99 forward ) with a v10.
by the way, plowing snow kills auto tranys. If you are going to do that much, go for a stick shift.
__________________
  #15 (permalink)
bill11012's Avatar
__________________
Tags
1985 , 1989 , 460 , 75 , 75l , f250 , f350 , ford , gas , kind , mileage , motor , mpg , reviews , v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
