Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 06-29-2009, 09:20 PM
Pompanosix Pompanosix is offline
Pompanosix is starting off with a positive reputation.
That would be a nice project for me. Looks like I'll have to head down to Miami and check out the JYs down there. There is a decent selection down there, but I agree one needs a bit of luck to find such a part. Sounds like a lot of work....time to use the search and read up on it. Thank you!
Worst case scenerio, I'll just put a MC fan clutch and see how that goes.
__________________
1994.....F-150....300-6...E4OD....Short Box/Reg Cab....2WD...
  #17 (permalink)
That would be a nice project for me. Looks like I'll have to head down to Miami and check out the JYs down there. There is a decedent selection down there, but I agree one needs a bit of luck to find such a part. Sounds like a lot of work....time to use the search and read up on it. Thank you!
__________________
  #18 (permalink)
Old 06-30-2009, 12:09 AM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
Yeah, it's a cool project if you like to "fiddle with your truck" or try things to see if they work. Once you dial it in, they seem to work really well.
The Crown Vic\ Grand Marquis\Town Car fans are plentiful and seem to work well on stock vehicles. The Mark VIII fans can be elusive, but I hear they will almost propel the car down the road by themselves.
I've also heard a lot of good things about Ford Taurus fans and Ford Windstar dual fan setups from the hot rodders. That's some other plentiful options from the junk yard for you consider.
I spoke to my buddy for an update on his Crown Vic fan setup. He said that his setup is working "good enough" for now, and he's not had time to dial it in better. I'll pass on what he told me:
He found a 195*-On, 180*-Off sender that works well in the T-stat housing from Jegs, and will send me the part number. His fan is relay controlled, On or Off, no controller. He's had no battery or charging system issues.
With that temp range though, he feels the fan runs too much and may be trying to keep the motor too cool at idle. The factory gauge stays about centered, but those gauges give no actual Temp reference and are not accurate.
(I agree). He has not connected an actual temp gauge yet. That's where he left his system, pending further tweaking.
Note: Most OEM fans come On at about 215-220* on Ford products IIRC, but they're computer controlled. There'so actual fan sender. I'm thinking a sender with 220-on and 210*-off would be ideal if you can scour the catalogs and find one.
The AC in his Bronco (factory R134a) works great at idle/low speed with the CV fan set up to run with the AC on. Vent temps in the high 30s. with 85* ambient.
Hope this helps.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
Tags
1995 , f150 , ford , orifice , tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
