Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-14-2009, 03:37 PM
joslawn33 joslawn33 is offline
joslawn33 is starting off with a positive reputation.
Fluid in tires
Will adding fluid in my tires 86 f250 400 engine built to the gills .Buying new tires for sure. Will this help during tug a wars? with the added weight
  #2 (permalink)
Old 06-23-2009, 04:00 AM
77&79F250's Avatar
77&79F250 77&79F250 is offline
1979 Ford F-250
My Garage
77&79F250 is starting off with a positive reputation.
Why is this in 355 eng forum? Are you talking about foam filled, like tractor tires to prevent flats?
Guess it would work, for tugs only, not hwy driving. But I think it would be pretty expensive, it you got big tires. Might also need bead lock rims to prevent a blown bead.
Some folks might think its cheating, like having a brake light cut off switch, so the other guy doesn't know your brakes are on.
Or like using a manual choke cable to hold the rpm's up, while you are on the brakes and clutch.
Try putting a goose neck ball with a big steel plate in the bed. Hook up to the goose neck ball with a modified trailer hitch/big log chain or cable, harder the other guy pulls, he pulls down on your truck='s more traction for you.
Works good if you truck is taller than their's, any way good luck with it.
__________________
77&79 F250
77 400 auto, factory a/c add a leaf/285's
79 460 4 spd, factory a/c and 35's
79 400 4spd 6" Skyjacker Eledbrock-Holley-Hedeman 36's
99 Ranger Ext Cab Flairside V-6 245's
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
