Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-14-2009, 10:39 AM
hot51's Avatar
hot51 hot51 is offline
hot51 is starting off with a positive reputation.
79 ranchero trim
Does anyone know where I can get some trim peices for my ranchero? They can be used. I'm looking for the fender well peice it's a curved peice.
  #2 (permalink)
Old 06-17-2009, 04:30 AM
fl1a fl1a is offline
fl1a is starting off with a positive reputation.
Try looking on Ebay motors. Search Ranchero, LTD II and Country Squire. You see used
items there at different times. I would also recomend car-parts.com.
  #3 (permalink)
Old 06-17-2009, 05:12 AM
hot51's Avatar
Thanks I'll check it out.
  #4 (permalink)
Old 06-19-2009, 07:06 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by hot51 View Post
Does anyone know where I can get some trim peices for my ranchero? They can be used. I'm looking for the fender well piece it's a curved piece.
When you say fender, I assume you mean the front fenders, not the rears, which are known as quarter panels.
There are three different wheel opening type mouldings for Ranchero's.
A) One type is a wide curved anodized aluminum moulding, that fits around the inside of the wheel opening (D4OZ16038C Right / D4OZ16039C Left).
B) One is a wide anodized aluminum moulding that fits above the wheel opening, has extensions on either end, one goes towards the door, one towards the front (D7WY16038A Right / D7WY16039A Left).
C) The Ranchero Squire uses a one piece wood grained fiberglass fender moulding that fits above and below the fender (D7OZ16250A Right / D7OZ16251A Left).
The A mouldings ONLY were used on 1974/76 Torino/Merc Montego's & Cougars, as well as 1977/79 LTD II (not LTD), 1977/79 Cougars.
B & C were used on 1977/79 LTD II's and Cougars.
LTD II's have the same vertical stacked headlight arrangement as Ranchero's.
LTD's have side by side dual headlamps.
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
  #5 (permalink)
Old 06-19-2009, 07:24 AM
hot51's Avatar
The ones that I'm looking for are the ones that fit above the weel opening wide and anodized aluminum. I will have to check if it is riht or left side. Is this someting that you might have or know where to get one? This truck has them on the front and the back but I got one that is in real bad shape.
  #6 (permalink)
hot51's Avatar
  #7 (permalink)
Old 06-19-2009, 07:37 AM
Ford Parts Guru
To clarify:
Type B are partial wheel opening mouldings, fit above the wheel opening and have extensions on either end. One extension goes to the edge of the front door, the other towards the front.
Type A just screws into the entire inner lip of the front fender's wheel opening, has no extensions. Resembles the letter C.
__________________
  #8 (permalink)
Old 06-19-2009, 07:40 AM
hot51's Avatar
Yes you are right I need Type B
  #9 (permalink)
Old 06-19-2009, 07:52 AM
Ford Parts Guru
D7WY16038A .. Right Front Fender Moulding / Obsolete
No Ford Dealer or obsolete parts vendor has any.
D7WY16039A .. Left Front Fender Moulding / Obsolete
KINSEL L/M in Beaumont TX has ONE = 800-816-2894.
BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675. This dealer is HIGH BUCK!
PARTS INTERNATIONAL in Farmers Branch TX has ONE = 888-727-0418.
ED BENNETT FORD PARTS in Lebanon PA has TWO = 717-272-8762.
FACT: Right side body parts are usually harder to find than the left sides, because most accidents occur on the right side. No kidding.
Left side internal parts for doors and windows are harder to find than right sides.
Welcome to FTE
__________________
  #10 (permalink)
Old 06-19-2009, 08:18 AM
hot51's Avatar
Thanks for the information I will call some of them.
  #11 (permalink)
Old 06-19-2009, 08:19 AM
hot51's Avatar
Do the rear ones have the same part number
  #12 (permalink)
Old 06-24-2009, 02:08 PM
hot51's Avatar
number Dummy
I gave you the wrong information the other day the peice of trim that I need is the passsanger side rear type B. Do you know the part number for this all I need is the curved peice I have the two eends that attach to it.
  #13 (permalink)
Old 07-06-2009, 06:34 AM
Ford Parts Guru
number Dummy
The front & rear wheel opening mouldings are not the same.
There are two types of rear mouldings.
D7OZ9729164A .. Right Rear Wheel Opening Moulding / Obsolete
Fits inside the lip of the wheel opening, C shaped. The front/rear mouldings are separate pieces.
D7OZ9729140A .. Right Rear Quarter Panel Moulding
This is a one piece side moulding, the wheel opening portion fits above the wheel opening.
Thse two mouldings fit 1977/79 Ranchero's only.
__________________
Tags
1973 , 197779 , 79 , body , door , lip , molding , moldings , opening , panel , panels , pieces , ranchero , trim , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
