Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #121 (permalink)
Old 09-03-2009, 10:12 AM
Broncoholic1's Avatar
Broncoholic1 Broncoholic1 is offline
Broncoholic1 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Broncoholic1 View Post
Those studs are so small prolly 1/2 to the cooling jacket.
I got em in with no green stuff... Are you using Horror Freight taps. Aluminum is pretty soft stuff.
That was for the guy who keeps breaking taps off.
I use CTD drills:
Here is a link to get some from Jimmie:
http://www.jimnewmansales.com/ctdbrochure1.html
I used to sell these to the Ford Rouge Plant Best when I was the rep. These are the best all around w 135 deg. points. You can get individual size or the 29 pc. std. set. I need a left hand 190 AL set thanks for reminding me.
I gave them a lifetime guarantee to the Ford Guy's had to replace 1 - 2 per month every time I came back for another orderThose guy's loved the lifetime warranty.
The taps are also some of the best around, never broke one.
I did not jack it up, might help tho kind tight in there. You will need a right angle drill, or 90 deg. die grinder with a steady hand do not rush it.
  #122 (permalink)
Old 09-03-2009, 07:43 PM
Gene/F-53/V10 Gene/F-53/V10 is offline
Gene/F-53/V10 is starting off with a positive reputation.
Thanks for the suggestion on a better quality bit & Tap set. Will look into it for the future. Right now, slowly concentrating on chewing out the center of the broken tap with Carbide bits, takes patience and walk away time.
Today, had to walk away after Dremel off/on switch bit the dust, went over an borrowed my sons, so back to the battle tomorrow, very close to the end of the tap, just one full tooth set hanging on, then the step or ground down nose end taps, then it should fall out.
Then to try to tap the treads to clean it out, wish me luck, then it's reassembly time, can't wait. Will keep y'all posted, it's really been a journey!
  #123 (permalink)
Old 09-03-2009, 08:15 PM
AnnesLimo's Avatar
AnnesLimo AnnesLimo is offline
1999 Lincoln Navigator
My Garage
AnnesLimo is starting off with a positive reputation.
My bad!!!
Dhope!; sorry I thought your reply was to me... Anywho I'm all up and in it now and can I just say weeeeeeee!!!!???
So here is where I'm at after 3 hours... Got the wheel, ineer skirt and shock / mount off on the passenger side and found 4 broken bolts one (that I can see) flush to the head. I hustled on off to Autozone and got me a couple cans of pb and some metric impact sockets. Also wandered by Harbor freight for some cheap just in case tools...
Total $$$ spent so far $22.00 new gaskets and bolts, $49.00 Harbor Freight for 6 ton jack stands and other misc. pry tools and $25.00 at Autozone for PB and socket set.
As of now I have 5 of 6 bolts out (4 are previously broken off) and one left to go on the passenger side. I have found that I'm using a combo of 1/2", 7/16, 11mm and 12mm sockets with 1/2" breaker bar and 3/8" ratchet and breaker bar. I do not know if I'm just catching some luck today or if all those Delta Sonic superkiss car washes with chassis baths are paying off, but all 5 bolts I've extracted came out without a hitch nut & bolt in one piece! Best I count my luck stars and wait to profess my luck after I get the broken ones extracted!
I am certainly taking my time and excorsizing patience which I believe is helping out with my success to date. I will be posting pics later...
  #124 (permalink)
Old 09-03-2009, 08:47 PM
AnnesLimo's Avatar
My Garage
Some pics
Mechanics zone!
The tool shed
Love the thumbwheel
Break time
  #125 (permalink)
Old 09-03-2009, 10:19 PM
AnnesLimo's Avatar
My Garage
The truck up high
The target passenger side
The parts bin
First one came out with ease
Got one more left still in tact but the little bugger is hard to get to and the nut is rounded off a bit. This one of course is a lower stud abouve the motor mount so I can't even see it well enough to grind it off... Looks like a trip to sears is in order for a rounded nut grabber socket!
  #126 (permalink)
Old 09-04-2009, 12:53 AM
Oh you have an Excursion, that explains it. Your truck never saw a days work in it's life
Looks like you dodged a bullet, Salt kills them round here...
  #127 (permalink)
Old 09-04-2009, 01:21 AM
AnnesLimo's Avatar
My Garage
Work? What's that??? Salt? Not in western NY!!!
I can't pretend to know what you consider work but I've got 180,000 miles of hauling boats, cars, trailers and pushing a plow (note the plow frame on the front)!!!
But seriuosly this excursion was bought for working not shopping and I am totally suprised at how good things look underneath her after 10 years of hard labor.
As a side note; I am only 25% through this project so we shall see if my bullet dodging prevails!
  #128 (permalink)
Old 09-04-2009, 01:27 AM
AnnesLimo's Avatar
My Garage
So, while I'm at it I figured I will replace the shocks and everyone seems to love the Bilsteins... Any suggestions here for hauling and handling? I'm looking at the Monroes, Ranchos or Bilsteins???
  #129 (permalink)
Old 09-04-2009, 04:26 AM
easternmike's Avatar
easternmike easternmike is offline
easternmike is starting off with a positive reputation.
I done both sides, my bolts were broken just like that, even with the depth of he manifold. Took me about 6 hours each side. My bolts were a little ruster than those shows. Tips: Use a 6 point 12 mm socket (a few were 1/2 in size. (Dont use PB on the ones not broken, that way it will bring out the studs with them) Use a 6 point socket after wire brushing nuts and pound them ojn carefully. (YOU DO NOT WHAT TO ROUND THE NUTS OFF) After the manifold is removed use PB on the studs that have about 1/2 to 3/4 inches available for a pipe wrench, use a very small pipewrench and a newer one that will bite good, about a 6 inch pipe wrench. Install new studs, use anti siese greese, dont put them in very tight, use torqe specs. GOOD LUCKm it is scary.
  #130 (permalink)
Old 09-04-2009, 09:59 AM
Quote:
Nice limo. go with the Bils top of the line, 25% more tho.
Get another 100K out of them. Might want to consider coil overs with the plow set up.
We can only hope you start to have a bad time like the rest of us. You should put an add in CL for Ford Stud removal. If they are all that easy you will make a mint. The repair goes for around $500 plus studs.
When you put them back use SS marine studs with lots of Anti-Sieze. Bullet dodged so far. Time will tell.
All the shops in MI will not touch them due to recalls.
  #131 (permalink)
Old 09-04-2009, 09:40 PM
AnnesLimo's Avatar
My Garage
Good luck gone bad
Well, so much for the good luck! On the right side I have 9 of ten out thanks to the craftsman bolt extractor kit I picked up Unfortunately I have one broken off in the head port #2 top form the rear. I have a right angle close quarters drill and left hand bits but all I've managed to do so far is chew it up and come dangerously close to cutting into the head. It seams no matter what angle I try to come from I can not get a straight shot at the center due to lack of clearence. Tomorrow I will see if I can find some stubby drill bits...
The other three broken ones had meat which I was able to grab and extract with the craftsman sockets
I used an air grinder cutting wheel to cut the bolts and seperate the y pipe flange from the manifold
I don't think these parts wer meant to look like this but hey it has been 180,000 miles!
Now I have two issues to face tomorrow the first being the drilling and extraction of that recessed stub and the second will be getting the studs out of the manifold flange.
Any suggestions would be welcome...
  #132 (permalink)
Old 09-04-2009, 09:55 PM
saskdiesel saskdiesel is offline
saskdiesel is starting off with a positive reputation.
You've had a hell of a fight here. I never had to chase any of the threads in my heads. Are the studs seized to the aluminum?
I can only imagine how frustating this is, because I've been there.
Once its done you can think about the money (a lot) you've saved. Any garage charges straight time for epairs like these.
  #133 (permalink)
Old 09-04-2009, 09:58 PM
I would just drill them out and tap new holes. You can easily enlarge the coresponding hole in the flange to match.
  #134 (permalink)
Old 09-04-2009, 10:04 PM
AnnesLimo's Avatar
My Garage
Quote:
I thought about that but was concerned my holes might not line up when its all said and done. This is a project unlike any I've done since I was 17 and swapped my Mopar 318 out for a 440 six pack in my 72 Charger. I think that was easier than this.
  #135 (permalink)
Old 09-05-2009, 12:01 AM
Pinky Demon Pinky Demon is offline
Pinky Demon is starting off with a positive reputation.
Owned.
__________________
2002 F-250 - V10, Crew Cab, Short Bed, Lariat 4x4 aka My Lovely Big Girl.
Click HERE for my full review w/ pictures of the Banks Powerpack Exhaust System.
Tags
aluminum , bolts , broken , egr , exhasut , exhaust , f150 , f250 , ford , heads , pipe , removing , rusted , studs , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
