Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #181 (permalink)
Old 09-20-2009, 10:38 AM
AnnesLimo's Avatar
AnnesLimo AnnesLimo is offline
1999 Lincoln Navigator
My Garage
AnnesLimo is starting off with a positive reputation.
Ugh, this is a post that reflects my greatest fear about this issue. I vote for the headers if you can swing it in the budget and plan on keeping the truck.
Quote:
Originally Posted by windyhill View Post
I replaced all the studs last year with new ones on my F350, 4x4, v10 a total PITA!!! less then a year later the pass. side popped off a stud head and started leaking again!!! I replaced that stud but it still is ticking around the gasket. I'm so pissed off at this point I can't see straight!! I used Ford studs, (the parts guy said they improved them) and torqued every thing down to specs. I even ran a streight edge on my manifold and it didn't look warped that I could tell. At a total loss! Do I buy a new manifold for that side and do one side over (ten more broken studs I'm sure by the time I'm done) or go headers and do both sides. I just want it to stop leaking!!!!!!
  #182 (permalink)
Old 09-20-2009, 09:57 PM
windyhill's Avatar
windyhill windyhill is offline
windyhill is starting off with a positive reputation.
a
Quote:
Originally Posted by Broncoholic1 View Post
Thanks FFL
Got a few lined up round here
Windy
Use some high temp gasket maker on the manifold. On my Big blocks I just mill the manifold & use high temp with no gasket at all. Works every time. I am not sure on the V10 my studs have yet to leak, Even tho I have one that is broken off in the middle lower position.
What kind, like black Permatex? or is it something else? The biggest problem for me is the thought of having to do the job over again on both sides and spending even a penny more on Ford studs, I'd love to take my broken studs and ram them up the designers...sorry. I''m considering headers but at around $600 it seams like a lot of $ for something that won't really feel like it makes much of a difference in the power department. If I did, are the doug thornly headers the way to go? and do they come with all the hardware?
__________________
'01 F-350 super cab, 4x4, SRW 3:73's,v10, 5 speed XL
'06 E-350 Superduty Van 4x4, 4:10 ls, v10 XLT!
  #183 (permalink)
Old 09-20-2009, 10:14 PM
Pinky Demon Pinky Demon is offline
Pinky Demon is starting off with a positive reputation.
I like the Banks TorqueTubes, and yes they do come with all needed hardware.
__________________
2002 F-250 - V10, Crew Cab, Short Bed, Lariat 4x4 aka My Lovely Big Girl.
Click HERE for my full review w/ pictures of the Banks Powerpack Exhaust System.
  #184 (permalink)
Old 09-22-2009, 07:15 AM
RobH1965 RobH1965 is offline
RobH1965 is starting off with a positive reputation.
Just plain lucky
I decided to tackle my broken p/s exhaust manifold studs and I am happy to say that the V10 gods were with me. The toughest part was disconnecting the exhaust manifold from the engine pipe and ultimately I had to cut the studs and replace with bolts. Working off my back, even with a long extension and a universal joint I just couldn't get a good bite on the nut and it rounded. The 4 snapped manifold studs came out easily with just a small pipe wrench and I replaced them with grade 10.9 bolts from grainger. All told about 6 hrs labor and $25 in parts and the job is complete. Thanks to all who posted with information for this repair.
  #185 (permalink)
Old 09-27-2009, 01:49 AM
Broncoholic1's Avatar
Broncoholic1 Broncoholic1 is offline
Broncoholic1 is gaining momentum as a positive member of FTE.
Sorry so late for the reply
Here is what we use:
Ultra Copper Max Temp Silicone ..
Works great on the dump trucks, never had a leak. Not real sure about the cast & aluminum mix...on the V10.s Next time I will use it, When I replace the stud that just broke off again...
__________________
Ford Trucks are Like Lay's Potato Chips, You can't have just 1
69 Bronco 1/2 cab, 71 Bronco Wagon, 76 Bronco , 77 Bronco 1976, F250 Highboy, 1979 F150 SB, 1979 F150 SB Mudder, 1989 F250 2wd, 1979 F350 Monster 5.9 1999 F250 SD V10, 1988 Conquest Class A
  #186 (permalink)
Old 09-28-2009, 08:36 PM
windyhill's Avatar
Just finished pulling the passenger side man. off again and replacing all the bolts gasket and had the manifold machined. There was one stud broken and the heads so rusted on 5 of them that I couldn't get a socket on them. I bought these less then a year ago from ford (they where meant to be the better ones) Total bull ****. I took the stud back and showed them to the service guy today and had some words for them. By the end of the conversation the main manager, the head tech and the service woman where all there. When the head tech told me how I couldn't prove that I'd actuality used the studs that I had bought from them I lost it! What a *******! The Ford Tech also told me that I couldn't machine the manifolds because of the close tolerances. He wanted me to spend $550 on a new manifold! He also told me that they have replaced tons of those studs and he's never seen any of the new ones come back yet. What a load of ****! When I talked to the parts guy on the way out he told me that one of the "new studs" that where put on his personal truck within two years had also broken and his truck was ticking again.
This time I bought the studs from summit racing and the gasket and it was way less then half the cost and look like better bolts. I would have liked headers but can't justify the $700 for them.
How on earth did ford get away without putting out a recall on these POS bolts?!!!!
__________________
  #187 (permalink)
Old 09-28-2009, 10:27 PM
turbo10 turbo10 is offline
turbo10 is starting off with a positive reputation.
2 years ago I put a set of Advance Auto studs in my Ex. $13.68 for 10 of them. 4 months ago when I pulled my d/s manifold back off the studs were still in good condition.
put a set in my dads 01 5.4 f150 about 15 months ago and all is OK so far.. just my 2c
__________________
Black 04 Ex V10 63k miles. Custom turbo kit with Turbonetics 62-1 turbo new SS lines dual walbro 255 pumps, FMS Cobra 39lb inj. Custom built header on drivers side with 3" up-pipe. Large FMIC, 10lb boost,Tial BOV. 3" down-pipe to 4" magnaflow exhaust. tuned by tricktuners.com
Tags
aluminum , bolts , broken , egr , exhasut , exhaust , f150 , f250 , ford , heads , pipe , removing , rusted , studs , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
