LED Instrument Cluster Light Swap...anyone got a picture?
Old 06-15-2009, 10:12 AM
fasthauler's Avatar
fasthauler
fasthauler is offline
Originally Posted by TheBlueMule
i did this swap a few months ago. I love it, but i have one problem since i've replaced the bulbs. The one on the right side of the dash showing the temp and volt meter, will randomly go on and off. It will go out for a mile or two, then come back on for a mile, then go out for a little more...etc. Does anyone know why it does that? I checked the connections on the back and don't see any tears in the circut paper, or lose bulbs. any ideas? I did however go with the blue. It matched my aftermarket radio, and i love them when they are all lit.
TheBlueMule
The simplest way to diagnose your problem would be to move the LED from the temp/voltmeter side to the oil/fuel side and see if the problem moved. (How the heck did you get a voltmeter and not an amp Gauge?) If the problem moved then it is the LED and not the circuitry to it. I did a lot of work with LED’s in my 40 plus years in the electronic industry and have seen intermittent LED’s, so it can happen.
Old 06-15-2009, 10:03 PM
bicyclemonkey's Avatar
bicyclemonkey
bicyclemonkey is offline
Is anyone using the 5x LED kit? Any pics since there's none on their site? For these they have listed green as well as blue/green as colors. Kind of hard to choose without seeing what they look like.
Old 06-16-2009, 12:14 AM
65f100_352's Avatar
65f100_352
65f100_352 is offline
I had the 1 LED bulbs in my 78 and loved them! They are brighter than the stockers, if you remove the light filter. I dont understand why the dimmer wouldnt work, it worked on mine? Then again I only replaced the bulbs for the cluster light, and turn signals.
Heres a cheaper alternative:
LEDLight.com: Online Shopping for LED Lighting Products
just my 2¢
Old 06-16-2009, 03:29 PM
Damstr8's Avatar
Damstr8
Damstr8 is offline
just my 2¢
Which of the 1 LED bulb ones did you use?
Old 06-16-2009, 04:38 PM
berry1234's Avatar
berry1234
berry1234 is offline
I like the old green look via the ol' Tommy Edison way.
Old 06-17-2009, 03:12 AM
65f100_352's Avatar
65f100_352
I got mine off of ebay in a lot of 12 I think for about 10 or 11 bucks. Pretty good deal. I think that this was them:
Short Round 1 L.E.D. T10 Wedge LED Light bulb - Automotive LED Lights - LEDLight
Old 06-18-2009, 11:45 AM
zak8tac's Avatar
zak8tac
zak8tac is offline
When installing the LED kit, are there blue little covers you have to do away with like there are for the lights/wiper slots on the bezel? Or is it just a plug in and there ya go type of thing?
Old 06-21-2009, 09:37 PM
smithwoods's Avatar
smithwoods
smithwoods is offline
Change JUST the two illumination bulbs, leave the rest original. Leds make the turn and hi beam lights way too bright and they aren't the problem anyway. I did the green ones and it is most excellence, first time I can see the dash at night in 20 years.
Old 06-22-2009, 10:53 AM
jsutton's Avatar
jsutton
jsutton is offline
I just bought my LED's saturday (only the two illumination bulbs) and I'll be installing them today after I get off work. I was going to take a before picture last night but the lights were so dim they didn't even show up on the camera screen. The only ones they had at the store were Amber. So I'm leaving the covers in place and hoping yellow and blue make green. LOL even if it doesn't make green it'll still be brighter than what I had. I got the ones with 4 LEDs.
Old 02-23-2013, 01:21 AM
bradford237's Avatar
bradford237
bradford237 is offline
I've been hunting for a thread about this LED conversion. I just swapped out all my incandescent 194 bulbs out with the 5 led replacements. I tested them all with a 9v battery to make sure they worked and then installed them. Problem is none of them are coming on except the top light that lights up the little blue light about the speedo. Any suggestions here?
Old 02-23-2013, 08:59 AM
fasthauler's Avatar
fasthauler
You know that they are polarity sensitive, did you try to rotate them 180 degrees and see if they work?
Old 02-23-2013, 09:36 AM
smithwoods's Avatar
smithwoods
try turning the bulbs around in the socket, LEDs only light in one direction
  #28
Old 02-23-2013, 11:22 AM
bradford237
Yep turned them around and nothin even cleaned up all te copper contacts. Is there a voltage reducer or anything that causes the voltage to be lower?
  #29
Old 02-23-2013, 11:35 AM
smithwoods's Avatar
smithwoods
stick the old lights back in and see if they work, if not look for a broken path on the printed circuit board.
Luke76
87
11-01-2021 08:10 PM
lmarkie
05-04-2017 09:00 PM
Gichael
04-26-2017 07:02 PM
Ffbryce1
Electrical Systems/Wiring
06-08-2016 01:32 AM
MKLC
01-08-2016 08:56 PM
Quick Reply: LED Instrument Cluster Light Swap...anyone got a picture?
