Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-13-2009, 01:02 AM
Suppoko Suppoko is offline
Suppoko is starting off with a positive reputation.
troubleshooting tailgate issue
Well with the help of you guys last time I saved myself a lot of money by not purchasing a new tailgate motor and was able to get the window back up THANKS!!! Now it's summer and time to fix the problem, the window will not roll down with either the key in the back or the switch up front. What is the best way to proceed? And don't worry I won't be offended if you use very basic strategy I don't mind. Thanks for reading
  #2 (permalink)
Old 06-13-2009, 01:26 AM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
Lube the weatherstriping first.
Take the access panel off from inside the truck, it's a phillips head screw
Lube the dry hinge points.
Check for motor operation by jumping to power
If the motor works, check switches for contact corrosion, clean or replace if necessary.
  #3 (permalink)
Old 06-13-2009, 01:32 AM
Yeah I know the motor works because a friend and I hit it with a battery and that's how we got it to go up for the winter. I'll check the switches thanks sir
  #4 (permalink)
Old 06-13-2009, 01:36 AM
g_k50's Avatar
1990 Ford Bronco
My Garage
Having re-read your previous posts, we know that it's not the motor.
Jump the motor from inside the truck thru the access panel hole.
  #5 (permalink)
Old 06-14-2009, 06:49 PM
Aciancio's Avatar
Aciancio Aciancio is offline
Aciancio is starting off with a positive reputation.
I would bet that it is the safety switch in the driver side latch. what condition are your strike bolts in? try leaning into the tailgate on the drivers side while someone hits the dash switch. oh ya what year is your bronco so I can look up your wiring?
  #6 (permalink)
Old 06-15-2009, 01:15 AM
Quote:
96 EB the bolts seemed ok last time I looked but since the window is up its not a good idea to try and drop the gate. and the contacts looked ok from waht I can tell. I'll try leaning on it tommorow
  #7 (permalink)
Old 06-15-2009, 01:49 AM
Aciancio's Avatar
again I would bet it is the safety switch, but if its not how good are you with a volt meter?
  #8 (permalink)
Old 06-16-2009, 01:26 AM
I have one and can turn it on
  #9 (permalink)
Old 07-01-2009, 01:34 AM
ok I pushed the ever loving heck out of the drivers side while someone used the button and for fun the key in the back. Did not work, any more suggestions?
  #10 (permalink)
Old 07-01-2009, 11:25 PM
Aciancio's Avatar
OK pull off the driver side tail light. the plug for the tailgate is behind it check it from there. do you have a wiring diagram?
  #11 (permalink)
Old 07-05-2009, 10:35 PM
twisted limb twisted limb is offline
twisted limb is starting off with a positive reputation.
Just a note..My last Bronco rear window would not work with one of the switches, can't remember now which one.Found wire harness had broken wire from opening and closing tailgate.Found it right where it bends, easy to check .
  #12 (permalink)
Old 08-11-2009, 01:09 AM
Ok school is done for a week I really wanna get this baby fixed, I have the chiltons for it taht would have the diagram correct? Should this not work what would stop be from just running a wire to the motor the batter and a switch of my own?
  #13 (permalink)
Old 08-11-2009, 04:46 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
I have never used the Chilton's for the Bronco always the Haynes. Truth is though, you have two different circuits that feed the gate window. Circuit 12 and circuit 14. Both are on auto-reset breakers instead of fuses. One is the power feed for the dashboard switch and the other is for the keyswitch. If neither of the switches will make the glass move it is most likely one of two issues. The interlock switch in the driver's side latch or a failed motor will the window motor from operating. Since we know the motor works, we can eliminate that possibility. The interlock on the latch will not allow the window to move if the latch isn't fully engaged (i.e. the gate isn't shut tight or the striker bolt is missing the bushing around the bolt) or the adjustment of the latch is off. Check the condition and alignment of the striker bolt on the driver's side first to be sure the latch is fully closing. A misaligned striker or missing striker bushing would be the simplest fix. If there is no issue there, the interlock switch is the next thing to check. Don't rule out more obvious things like damaged wires where the wiring harness runs from body to tailgate either.
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
  #14 (permalink)
Old 08-12-2009, 12:31 AM
yeah I pushed and banged on the driver side with someone hitting the switch and nothing budged it. When I take the tailgate down how do I know if it's aligned right? I mean the thing shuts so I assumned it's aligned. And where is the safety switch? and while i'm at it where is the interlock switch? Why can't you guys live in Michigan? lol
  #15 (permalink)
Old 08-12-2009, 02:05 AM
1992 Ford Bronco
Because I have too many shows to do here in STL, MO. But aside from that, the switch is a small proximity switch mounted to the back side of the latch. Getting at it is tedious but not impossible. To check the switch, open the gate and then manually close the driver's side latch. You will need to push both sides of the latch simultaneously otherwise closing one side releases the other. Fully closed, the two halves of the latch should form a near perfect circle at the center of the two halves (the size of the striker bolt shaft oddly enough). This way you can see that the latch is fully closed. Try to operate the window from each of the switches. If the window works, you know you have a latch alignment issue. If not, you have to dig further into the gate and get at the interlock switch to test it. While it isn't necessary to remove the latch/switch, it does make getting at it easier. Check too before you do anything that the wires to the interlock switch haven't merely broken off or corroded away from the switch.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
