Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-12-2009, 12:35 PM
64F-100's Avatar
64F-100 64F-100 is offline
64F-100 is starting off with a positive reputation.
Taillight Works - Sometimes
I've been fooling with the driver side tailight for months and I still can't get it to work all the time. The turn signal always works, but the taillight doesn't work. Sometimes, I drive the truck around town and when I get home I'll check to see if the tailight is working and it is, but then sometimes it doesn't. If I just start it up and turn the lights in in the driveway, it doesn't work. Neither does the brake light on that side. The bulb is new, both filaments in the bulb look good. I pulled the entire taillight assembly out, cleaned it up, cleaned the socket (bed) and put it back together and still, nothing. I pulled the plug apart, cleaned each half and still, same problem.
Also, not sure if this is related, but the passenger side front parking light never works either, but the turn signal works. That is a BRAND NEW assembly and bulb.
Could the switch inside the dash be bad?
__________________
Balz
1964 F-100 V8 4spd
2003 Thunderbird Roadster
1974 Ford LGT 145 Garden Tractor
  #2 (permalink)
Old 06-12-2009, 12:54 PM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
Help needed in the Cincinnati, OH area
Sometimes we can't see the trees for the forest. Maybe a shout out for another truck owner in the Cincinnati, OH area would prove helpful. Sometimes electrical issues can be a real pita to locate but usually are simple when found.
Dirt is a huge culprit, chaffed wires another. Dirt can cause the lack of grounding. When a system works part time grounding rises to the top.
If I could get my hands on your truck, I suspect we could resolve your issues in an hour or less, but I can't see it from NC.
Hope someone will offer to help you.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #3 (permalink)
Old 06-12-2009, 12:58 PM
64F-100's Avatar
Thanks. The wiring looks ok, but I haven't gotten the multimeter out yet so who knows.
__________________
Balz
1964 F-100 V8 4spd
  #4 (permalink)
Old 06-12-2009, 06:50 PM
daveengelson's Avatar
daveengelson daveengelson is offline
daveengelson is gaining momentum as a positive member of FTE. daveengelson is gaining momentum as a positive member of FTE.
May try checking the taillight sockets. Had simular experience that was driving me up the walls, taillight would start acting up and I would fiddle with the rear bulbs until they both worked, unfortunately it was a short term remedy. Found the bulb sockets were badly corroded and the leads where not making contact with the bulb. Already repaired the sockets on couple occasions so finally decided to replace.
__________________
'problem with engaging in useless activity is never knowing when your done'
Never engage in a battle of wits half armed!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
  #5 (permalink)
Old 07-01-2009, 01:07 PM
caspery caspery is offline
caspery is starting off with a positive reputation.
I have the same problem. I replaced the brake light switch on the master cylinder but that didn't help.
Brake lights still works intermittently. I now have the steering wheel off and I am cleaning the turn signal switch. Brake lights operate through the switch( for some reason) and if the switch wears out the brake lights don't work.
It is also my opportunity to replace the delicate plastic turn signal release cam that turns off the signal after a turn. Mine's broken on one side.
I have even replaced the rear wire harness from th firewall back.
So, in my case, it must be the turn signal switch.
  #6 (permalink)
Old 07-01-2009, 01:13 PM
64F-100's Avatar
Hmmm. My turn signal switch is pretty wore out too...No release cam left whatsoever, however the turn signals themselves work all the time. Let em know if that fixes it.
Thanks
__________________
Balz
1964 F-100 V8 4spd
  #7 (permalink)
Old 07-01-2009, 02:47 PM
JRB65 JRB65 is offline
JRB65 is starting off with a positive reputation.
I had to take a pair of Needle Nose Plyers and squeeze the socket a little because the bulb was working its way out just slightly. So I dont know if this will help but you may want to give it a try.
JRB65
  #8 (permalink)
Old 07-01-2009, 03:02 PM
BarnieTrk BarnieTrk is offline
BarnieTrk is starting off with a positive reputation.
Mine's broken on one side. So, in my case, it must be the turn signal switch.
Caspery,
How much of a job is it to get to & replace the turn signal switch?
Is the cam part of the switch?
I think I need to replace mine - since the turn signal lever can turn itself on if I hit a pothole...... (Mine is a '63 steering column but it's in my '65 F100 truck.)
BarnieTrk
__________________
- 2WD '65 F100 short box, 390" FE, T-18 4spd
- 2WD '65 F250 long box, 390" FE, T170FT 4spd OD
- 2WD '94 Ranger XLT, r/cab, 139" (2.3L) 4-cyl, 5spd
  #9 (permalink)
Old 07-01-2009, 04:25 PM
Locate the replacement parts first. I have a 66 F250 with a 4 speed. It has a replaceable cam. I have an F100 colimn that looks like you replace the entire switch.
You'll have to remove your steering wheel.
Remove the turn signal lever.
Remove two small screws that hold on a trim piece.
Looks like 3 screws hold the switch in place.
It has to be removed by threading the wire harness out of the column.Then do the reverse t install the new one.
  #10 (permalink)
Old 07-01-2009, 04:58 PM
Thanks! Sounds do-able.
BarnieTrk
__________________
  #11 (permalink)
Old 07-01-2009, 09:32 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a good reputation on FTE. garbz2 has a good reputation on FTE.
Check the outlet at the firewall for the wiring it is a notorious spot for corrosion and will work and not work. Also check the split for front to rear for the tail lights. It is down near frame by the cab mount. They are not weather pak connectors and corrode.
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive 410, C6.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
  #12 (permalink)
Old 07-01-2009, 10:14 PM
inxquve inxquve is offline
1965 Ford F-250
inxquve is starting off with a positive reputation.
The tail lights share a common feed, so if one is working and the other not, it's specific to that fixture. Could be the socket itself, or the junction where the wires split to each side. Since the turn signal works I would say the ground is probably good.
The tail lights and turn/brake lights are separate circuits; bulb and socket are the only thing they have in common.
The brake lights go through the turn signal switch because they use the same filament. When the turn signal switch is in center position, the brake switch feeds power to both lights. When you move the switch, it shuts off the power from the brake switch for that side and instead provides it's power through the flasher. That way the light will still flash while the brakes are applied.
I just rewired my '65 from scratch. Took me a while to understand the turn signal switch too, but it makes perfect sense now.
  #13 (permalink)
Old 07-04-2009, 02:46 AM
IsoGrifo's Avatar
IsoGrifo IsoGrifo is offline
IsoGrifo is starting off with a positive reputation.
I have the same problem! But I know the problem! for once! lol
So the turn signal switch actually in the column is broken, so it doesn't like to stay in the middle. (side note, I tested this in a garage with the door down) when i moved the switch down a little bit, lower than it should be but not turning on the signal, it cut out my driver's side tail light, when i moved it back to center, BINGO! light came on! simple fix if you have a steering wheel puller.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
