Is my tach sensor the culprit?
Old 06-12-2009, 02:54 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
Question Is my tach sensor the culprit?
I searched, couldn't find anything relating to my specific problem. When my truck is cold, the tach doesn't work at all. After about 5 minutes of driving it begins to function, how accurately it functions is a mystery. The idle speed it shows is usually different every time I stop. When I use the turn signals, the tach needle bounces(2-300rpm) in sync with the blinker. Could this be the sensor or a cluster issue?
Old 06-12-2009, 07:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Sounds like a dash connection problem to me for the most part because of the blinker induced bounce.
Old 06-12-2009, 09:22 PM
royzell's Avatar
royzell
royzell is offline
I just replaced my tach sensor, and the tach was doing all kinds of weird things like you described (IIRC - even blinker bounce). Got any spare parts, or temporary access to another tach sensor ?
Old 06-12-2009, 09:32 PM
Sycostang67
Not yet, it's my first diesel and I've only had it a few days. Haven't aquired any spare parts yet.
Old 06-12-2009, 09:46 PM
GenLightening's Avatar
GenLightening
GenLightening is offline
Sounds like the sensor is going. Ford only part and about $60 or so, E5TZ-17B384-A TACH SENSOR
Old 06-12-2009, 09:49 PM
therifleman556's Avatar
therifleman556
therifleman556 is offline
Mine only works when you rev the engine. At idle and when coasting it reads zero. Where is this sensor anyways? I'd like to look into replacing it.
Old 06-12-2009, 09:54 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Tach Sensor Location
-Enjoy
fh : )_~
Old 06-12-2009, 10:15 PM
therifleman556
Awesome! Thanks! I think I'll just throw a new one in while I've got the motor out. Does that sensor have anything to do with how the PCM controlls the E4OD or is it a sending unit only?
Old 06-12-2009, 10:35 PM
GenLightening
It controls quite a bit. Without the sensor, the trans won't work correctly (as well as the TPS/FIPL, speedo drive, brake lights and gear selector). That's one of the reasons I went with a Baumann controller, less inputs to scramble the trans.
Old 06-12-2009, 10:53 PM
therifleman556
So the tach sensor could be causing my eratic tach operation and messing with the shifting? Are there any other variables to check?
Old 06-12-2009, 11:32 PM
GenLightening
That would cover both of those. You could check the grounds and connections for both, as that would also make it look like a falied component. I still vote for the sensor, they seem to go out after a few years (maybe 20?) of use.
Old 06-13-2009, 12:21 AM
88f150302's Avatar
88f150302
88f150302 is offline
ok i have a question my tach works when i am cranking it bouces but thats it when it starts it dosnt work at all could that be the sensor?
Old 06-13-2009, 01:13 AM
starmilt's Avatar
starmilt
starmilt is offline
Usually before the sensor fails the the insulation will be cracking and showing bare wires right as they come out of the sensor. If they are it is a sure thing the sensor will not be long for this world.
Old 06-13-2009, 11:16 AM
Sycostang67
I just noticed that last night on my sensor. The wire is bare for about 2" coming out of the sensor. Guess I will look for a new one.
Old 06-13-2009, 06:47 PM
Festus Hagen
Methanoholic
If it's still working, apply a little sillycone (silicone) around where the wires enter it to prevent moister from getting in and shorting it out. They are like something like 50 or 60 bux!
Yea, I know, I would replace it to!
-Enjoy
fh : )_~
Quick Reply: Is my tach sensor the culprit?
