Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-11-2009, 09:09 PM
hendedo hendedo is offline
hendedo is starting off with a positive reputation.
Recomended starter to buy
Hello all. We might have to replace the starter in the truck. (2wd, 4.2L, auto, 155K miles plus)
Is there a preferred brand of starter? I see most hovering around 135 to 155 dollars. Lots of rebuilts too. Truck is just used for transportation, not work. Thanks, Don.
  #2 (permalink)
Old 06-11-2009, 11:44 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
I have bought starters and alternators from Advance Auto on several occasions over the years.
Never had a problem with any of them.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #3 (permalink)
Old 06-21-2009, 05:13 PM
homerunswing homerunswing is offline
homerunswing is starting off with a positive reputation.
I just purchased a rebuilt starter from Rockauto, installed it yesterday with no problems, for a 2000 f150 4.2L. with core return of $45 it will be less than $100. truck had original starter, and I have had many NO CRANK issues over the last year. Codes would never show up when it was in the shop, until finally it showed "no amps". Changed to a new battery, ran OK for several months, no issues, then started with the "no crank" again. The brand I bought from Roackauto was BBB. There was a tech bulletin included, showing the ignition lead should be cut back 6", and replaced with the new lead which comes with the rebuilt starter. Hope this helps.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
