Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-11-2009, 08:39 PM
warren3527 warren3527 is offline
warren3527 is starting off with a positive reputation.
2000 F150 pull to the left
Hey folks, I have a 2000 F150 Supercab with a 5.4 and the off road package. Since I've had the truck it has always seemed to pull to the left. I've had multiple front end alignments done and it still always seems to pull. any ideas?
  #2 (permalink)
Old 06-11-2009, 09:30 PM
chaser1602 chaser1602 is offline
chaser1602 is starting off with a positive reputation.
Have the alignment shop line it up to the right a little but.I had a Pete that drove just fine but always p wore the tires t like it was pulling to one side.Moved the alignment over a little bit and it took care of it
  #3 (permalink)
Old 06-11-2009, 10:12 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) is gaining momentum as a positive member of FTE.
does the truck set level? pulls to the left with a driver in the seat. how is the spring adjustment?
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 190,000 miles
2002 Explorer 4 x 4 4.0 XLT - 120,000 miles
  #4 (permalink)
Old 06-12-2009, 12:59 AM
papajoemrt's Avatar
papajoemrt papajoemrt is offline
papajoemrt is starting off with a positive reputation.
i had the same problem on my 02 screw when we first got it.
when i went to crank the torsion bars one of the bars was cranked more than the other one to start. this is after multiple alignments from fords. it may be something you'll have to live with because it may pull to the left but it's more about extending the life of your tires.
__________________
2002 F-150 Screw
Kenwood DDX512, Pioneer Doors, Image Dynamic Subs
Dumped Flowmaster Super 40
Trans-Go Shift Kit
Gotts Intake Mod
  #5 (permalink)
Old 06-12-2009, 01:03 AM
aridranger03 aridranger03 is offline
aridranger03 is starting off with a positive reputation.
my dads 99 f-150 had the same problem when he bought it back in february, but it needed new tires and when he had some installed it fixed it
  #6 (permalink)
Old 06-17-2009, 02:02 PM
Quote:
would that not cause uneven tire wear? if not it sounds like a good idea but will they know how much?
  #7 (permalink)
Old 06-17-2009, 02:04 PM
Quote:
well i can only tell when i'm driving it...lol...but i guess you mean when it's only me. no, it pulls even when there is another person in the rig. i don't know anything about spring adjustments.
  #8 (permalink)
Old 06-17-2009, 02:07 PM
it's most noticeable when in the left lane on the freeway (but does it everywhere else too but just not as noticeable). i know the lanes are pitched to the left which helps cause the pull but when i'm in the right lane (pitched to the right) it drives straight. and on surface streets it pulls left and i have to "hold it" to drive straight.
  #9 (permalink)
Old 06-17-2009, 05:02 PM
papajoemrt's Avatar
checked the air in the tires? you've had multiple alignments but a tire that seems to look inflated could be underinflated. Just a thought.
__________________
2002 F-150 Screw
Trans-Go Shift Kit
Gotts Intake Mod
  #10 (permalink)
Old 06-17-2009, 10:16 PM
yeah i've always checked the tires. not that. thanks though
  #11 (permalink)
Old 06-17-2009, 11:25 PM
papajoemrt's Avatar
ya never know.
__________________
2002 F-150 Screw
Trans-Go Shift Kit
Gotts Intake Mod
  #12 (permalink)
Old 07-02-2009, 05:07 PM
took it up to belle tire for an alignment (just got new tires so wanted that anyway). they said all they can adjust is the tow (sp?). they also said it may need a "cam kit" which i am told is an adjustable bushing kit. thoughts?
  #13 (permalink)
Old 07-02-2009, 05:33 PM
papajoemrt's Avatar
my belle tire can do a full alignment, the best place to go for an alignment though is your ford dealer but it's a bit more pricey.
the cam kit is just a new bolt with two offset washer on them. i had them out when i did the ball joints on my truck and truthfully i can't see how they work but they must do something.
__________________
2002 F-150 Screw
Trans-Go Shift Kit
Gotts Intake Mod
  #14 (permalink)
Old 07-02-2009, 05:41 PM
well i have had the dealer do it. they are pricey as you say and even after it still pulled. why can one belle tire do more of an allignment than another?
  #15 (permalink)
Old 07-02-2009, 05:54 PM
cmorningstar01's Avatar
cmorningstar01 cmorningstar01 is offline
1997 Ford F-150
cmorningstar01 is starting off with a positive reputation.
Have someone follow you as you drive the truck and check to see that it is tracking properly. Watch the front and rear tires on both sides and check to make sure that they are following each other and not offset, It is possible that the track is off and is causing the pull and no amount of front wheel alignment will fix it, When I say track I mean the front tires are following the rear tires and not offset, If you take it somewhere with a frame alignment rack they can check it and possibly fix it if it is not too bad.
I am not saying this is your problem but it can cause the problems you are describing.
Val
__________________
1997 Ford F-150 Standard cab long bed 4.2 V6 Auto 3:55 gears, Flowmaster SIDSO catback system, Harland Sharp 1.8 Roller Rockers
2002 Mercury Sable LS Premium 3.0 24 valve V6
2001 Ford Windstar LX 3.8 V6 long wb(dog mobile for hauling the lab gang)only 2 seats upfront
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
