Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-03-2009, 11:12 AM
Tex1986 Tex1986 is offline
Tex1986 is starting off with a positive reputation.
Ok, I had the problem on my 98 xcab. Here's the deal. If you don't have the cam/caster bolts... GET EM!!! You NEED those. Otherwise, the techs will force it "in" by a prybar. These trucks come from the factory with a preset block through the upper control arm bolts. You can't adjust camber/caster until you put the kit in. Your local parts store should have them or the dealer. They are a piece of cakeOnce I put the bolts in and did the alignment myself... no more problem. Another cause might be brakes. Are they wearing unevenly, vibration when you hit the pedal? Brakes, tires, are there any loose front end parts like ball joints? Good luck
  #17 (permalink)
Old 07-03-2009, 11:14 AM
Papajoe, you honestly don't understand how the camber/caster kit works? As you stated, it's got two offset washers. When installed on the upper control arm, they adjust camber caster. The front moves your camber in and out and the rear moves your caster back and forward. If you'd like, I can send you some pics of mine and try and explain it better sir.
  #18 (permalink)
Old 07-03-2009, 07:49 PM
papajoemrt's Avatar
papajoemrt papajoemrt is offline
papajoemrt is starting off with a positive reputation.
No that's fine I don't do my own alignments and I thought there would be more to the kit than that and I can't believe that Ford charges around 50 bucks to put it in. I also didn't like how they said they installed them and I look and it isn't installed.
It is true what Tex said about the prybar though if anyone needs the second opinion. I know that much anyway.
__________________
2002 F-150 Screw
Kenwood DDX512, Pioneer Doors, Image Dynamic Subs
Dumped Flowmaster Super 40
Trans-Go Shift Kit
Gotts Intake Mod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
