Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-11-2009, 03:39 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is starting off with a positive reputation.
How long is Timing Chain good on 3.0 Vulcan?
Just wondering if I should be concerned to check/replace timing chain on my '92 Aerostar 3.0 Vulcan. It has 135,000 miles. Anybody have a chain go and at what miles? Maybe a non-issue?
__________________
'95 F150 XL, 2wd, 300 I6, 5 speed, 3.08 gear, 166,000+ miles, Flowtech Raptor muffler, driven hard for fun!
'92 Aerostar 3.0 Vulcan V6, auto, 134,000+ miles, Dynomax Super Turbo muffler
www.HonestEdu.org
  #2 (permalink)
Old 06-17-2009, 03:03 PM
TallPaul's Avatar
Whelp, I guess I've got nothing much to worry about. Seems there isn't enought timing chain problems on the Vulcan to elicit one response. Good!
__________________
www.HonestEdu.org
  #3 (permalink)
Old 06-18-2009, 07:41 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
TP, I replace my chain at 140k miles, not knowing if it had a plastic gear or all metal. The plastic-toothed gears get brittle and decide to turn into pieces about that mileage. I found that it has all metal gears.
If you do replace the gear, be aware that the bolt holding the cam gear in place is SPECIAL. It has an oil passage drilled to supply gear and chain lubrication.
Just check the amount of play you have on the crankshaft before it starts to turn the cam. At least you don't have to worry that the gear will come apart.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #4 (permalink)
Old 06-30-2009, 02:24 PM
TallPaul's Avatar
Thanks, I will try to get my mech to look at the play next time it's in the shop. I can't do it--am wayyyy toooo busy.
__________________
www.HonestEdu.org
  #5 (permalink)
Old 06-30-2009, 04:48 PM
FORD RANGER's Avatar
FORD RANGER FORD RANGER is offline
FORD RANGER has a good reputation on FTE. FORD RANGER has a good reputation on FTE.
i've never had any timing chain problems with my ranger and it has 168k miles on it.
__________________
jack, slackmaster #7
1996 ford ranger xlt extended cab,2wd,4.0L v6,5spd,3.08 gears, tornado intake spacer, msd ignition,sun super tach2, k&n air filter, nascar oil filter.
oregon chapter member
  #6 (permalink)
Old 07-01-2009, 10:47 PM
vjstangelo vjstangelo is offline
vjstangelo is starting off with a positive reputation.
1995 Taurus 3.0 Vulcan - 240,000 miles
I've owned it since 1996 (it was an off lease owned by my company prior to my purchase).
WRT the chain, my V6 has 240,000 miles on the original engine/transmission, and, the original chain. Short of the water pump, alternator, belt tensioner (all bolt-on accessories), the only significant issue has been an oil leak from the rear seal. Since I don't want to have the engine pulled just for that, she just drip, drips.
  #7 (permalink)
Old 07-02-2009, 02:17 AM
that means you have to get your hands dirty!! if i had a shop it would probably be easier!!
__________________
  #8 (permalink)
Old 07-23-2009, 07:42 AM
TallPaul's Avatar
Good enough for me. I'm not going to worry about the timing chain anymore. I'll print this thread so I don't forget. Yeah, that little 3.0 may be underpowered, but it is bulletproof, so long as you don't let her ping.
__________________
www.HonestEdu.org
Tags
2007 , 30 , 3o , 99 , bolt , bullet , chain , ford , ons , performance , proof , ranger , taurus , timing , v6 , vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
