Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-11-2009, 12:30 PM
zenmaster's Avatar
zenmaster zenmaster is offline
zenmaster is starting off with a positive reputation.
Best way to clean out gas tank?
Hey guys,
I have to clean out an in-cab gas tank. The PO let the truck sit for 15 years... so what would be the easiest (and cheapest) way to do that? I thought I might start by using varsol, or paint thinner, followed by gasoline. Is there a removable filter or screen I need to check in the tank? Anything I should be careful of? I get the feeling this is going to be a nasty job...
All input appreciated.
Thanks,
John
__________________
zenmaster
1967 M100 2WD T-18/ 240 inline six (project)
1972 F250 2WD T-18/ FE360 current daily driver
1977 F150 2WD 3spd column shift 300 inline six
  #2 (permalink)
Old 06-11-2009, 01:25 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
The best way to do it is pull it out and take to a radiator shop. In order to clean it properly yourself, you need to pull it out anyway.
  #3 (permalink)
Old 06-11-2009, 10:00 PM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
I vote for the radiator shop as well. It's really hard to get everything out of the tank by yourself.
  #4 (permalink)
Old 06-12-2009, 11:54 AM
zenmaster's Avatar
Thanks folks,
I pulled the tank yesterday... After setting it on end and banging it , I managed to dislodge about a pound or 2 of rust! I think the PO had tried at some point to use something to clean it, then just left it. I'm going to compare the cost of cleaning at the rad shop to the cost of a new one.
I pulled the sending unit- it's totally destroyed. Here are some pics:
Thanks again for you help,
John
__________________
zenmaster
  #5 (permalink)
Old 06-24-2009, 07:40 PM
daveengelson's Avatar
daveengelson daveengelson is offline
daveengelson is gaining momentum as a positive member of FTE. daveengelson is gaining momentum as a positive member of FTE.
Pulled the tank on the 65 and removed the sending unit and cut a section off a garden hose thus able to insert it into the tank so I could thoroughly flush the tank. Then used a cleaning agent and sloshed it around the tank, rinsed and repeated. Mixed a mild solution of metal etch and poured into the tank and then placed the tank in various positions and allowed to set 10-15 min's each to remove any rust then thoroughly flushing. I then let the tank bask in the sun for several hours. If detect any pitting, or holes, there's a sealant, Por 15 has a repair kit but but if the tank is in good shape suspect you can find simular products to clean the tank at a hardware store. I happen to like the Marine Clean, and Metal Etch, so had some on hand. Anyhow, this was over 10 years ago and have not had any problems.
__________________
'problem with engaging in useless activity is never knowing when your done'
Never engage in a battle of wits half armed!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
Tags
1977 , clean , cleanout , easiest , f150 , f250 , ford , fuel , gas , injection , pickup , por , rust , tank , tanks , truck , varsol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
