Door weatherstrip replacement
I've already visited this subject, so I'll be lazy and give you the thread links so you can read for yourself. The one thread "Progress on Buford" is mostly an overall progress report thread, but it does have some info on the door weatherstrip issue. I also have a couple pictures of the weatherstrip install in my photo album, so you can snoop there if you want.
https://www.ford-trucks.com/forums/754623-weatherstrip-install-technique-question.html
https://www.ford-trucks.com/forums/690861-progress-on-buford.html
https://www.ford-trucks.com/forums/757098-lmc-truck.html
Hope that helps.
Hope that helps.
Getting the old weatherstripping off is a pain in the rear. Get the good weatherstripping adhesive. Many say you have to remove ALL traces of old glue, well this is easier said that done. I got as much off as I could, sanded the edge to receive new glue, cleaned it and installed. It makes a huge difference in wind noise that is for sure.
Here is what I would do. Buy 3m black weatherstip adhesive. Be careful, they also make one that is yellow. Use the black because it will blend in with the new weatherstrip. Also, in my opinion, 3m makes the best. remove the old weatherstrip and use some laquer thinner to clean the old adhesive off. After that I would use a wax and grease remover to remove any foreign conatimates left behind by the solvent. apply the new adhesive to the weatherstrip AND the flange the weatherstrip adheres to. Let this dry for a few minutes until quite tacky. Apply another coat of adhesive to the inside of the weatherstrip and push it into place over the flange. Work your way around to the bottom where the seam is, that way if you need to trim at all it is not noticeable. I have had very good luck doing this.
Does it remove or mar the paint?
Thats all I use. I wont go back to using glue again. Matter of fact, I do not even use the stuff for the later Ford trucks. I have had better success with 90's era chebby S-10 weather strip. Something about the thickness, better suits our old rides. I have tired other stuff from cars and such, but the S series stuff has been the best so far.
