Question about synthetic motor oil in my 6.0L - Ford Truck Enthusiasts Forums
Old 06-11-2009, 10:21 AM
H2oSprayer's Avatar
H2oSprayer H2oSprayer is offline
H2oSprayer is starting off with a positive reputation.
It's time for an oil change and I am thinking about changing over to synthetic oil. PLEASE DON'T turn this thread into an oil brand war. I simply want to make sure that a 5w-40 synthetic oil will be fine for the midwest summer months while we tow our 8,000 lb trailer. We plan to take several extended trips and I have been changing my own oil at the 5,000 mile mark. Thanks for your thoughts.
Old 06-11-2009, 10:27 AM
ebusa ebusa is offline
ebusa is starting off with a positive reputation.
I just recently switched to Mobil 1 Turbo Diesel Truck 5w-40 Synthetic and instantly noticed easier starts and quieter at idle.
I'm sure I will really be able to tell the difference when the cold weather comes. I was previously using DELO 400 15-40, I've got 65k on my truck. I say go for it!
Old 06-11-2009, 11:17 AM
soberdude94's Avatar
soberdude94 soberdude94 is offline
soberdude94 is starting off with a positive reputation.
06 -250 here and I want to know about the Summer months in Hell with a zip code I mean Phoenix AZ is 5W-40 the right synthetic for me to use I pull A heavy rigg as well
Old 06-11-2009, 11:36 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
5W-40 and 15W-40 have the same high temp viscosity rating as in the 40 designation. Synthetic also tends to coke less at higher temps such as in the turbo than dino oil. the lower number designation is the viscosity rating when cold thus the 5W gives easier starting in cold temps. I think the syn. is a good choice if the cost does not bother you. You still should do 5,000 mile oil changes.
Old 06-11-2009, 11:57 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Many people run 5w-30 rated diesel oil, towing and all, so with a 5w-40 you'll be fine.
Old 06-11-2009, 12:16 PM
Guys thank you I will get to it then. One thing I was told with these 6.0'S that i should do a change every 3 to 4K miles or 250 Gallons of fuel used or 250 engine hours witch ever comes first so is 5K to many Miles?
Old 06-11-2009, 12:36 PM
5k is fine with a good synthetic as long as there isn't too much idle time and short trips.
Old 06-11-2009, 12:42 PM
H2oSprayer's Avatar
Thanks for the reply's guys. I'm gonna change to the 5w-40 synthetic later today.
Old 06-11-2009, 01:10 PM
origcharger origcharger is offline
origcharger has a good reputation on FTE.origcharger has a good reputation on FTE.
Quote:
I don't believe I have ever seen a diesel rated 5W-30 oil, there also seem to be few 10w-30s rated for diesels.
Old 06-11-2009, 01:15 PM
have to get a pic of my new rig in hear after I get the thing running again you can see my troubles in another thread
Old 06-11-2009, 01:27 PM
Quote:
AMSOIL - Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil (HDD)
From what I've read on the forums, there's quite a few people running this, even down in Texas where it gets HOT.
Old 06-11-2009, 01:33 PM
Amsoil? I guess I still hav'nt seen a diesel rated 5W-30 oil
Old 06-11-2009, 01:40 PM
I don't use any Amsoil products myself, but my next gear oil change will be to their Severe Gear oil, it cleans up in comparisons. Also, their 5w-30 oil is a VERY good oil. Please don't turn this into another ignorant Amsoil-hating thread.
Old 06-11-2009, 02:20 PM
No ignorance, I will keep it factual.
No Ford or International viscosity charts recommend or suggest the use of 5W-30 motor oil at temperatures above 30 degrees in their diesel engines.
Amsoil carefully words their application language such as below, note was it says and what it does not really say;
"is recommended for diesel engines and other applications requiring any of the listed worldwide specifications and gasoline engines requiring API SL, SJ, SH . . . or ACEA A3.
API CI-4+, CF, CF-2, SL ACEA A3/B3, E2, E3, E5 Global DHD-1 JASO DH-1 Mack EO-M+, EO-N Premium Plus 03 DDC Power Guard 93K214 Caterpillar ECF-1-a, ECF-2 Cummins CES 20071, 20072, 20076, 20077, 20078 Volvo VDS-2, VDS-3 MB 228.1, 228.3, 229.1 MAN 271/3275 MTU Type 2"
Old 06-11-2009, 05:55 PM
Troy Buenger's Avatar
Troy Buenger Troy Buenger is online now
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
Quote:
I'm from TX an ran the Rotella Syn. 5w-40 for 3 oil changes (15k miles) and each and every time when I would reach ~4k miles the injectors would get real loud at idle. When I would drain this oil it would drain out like water and the oil felt like it was a very low viscosity.
I went back to running Delvac 15w-40 with 2 quarts Mobil TDT 5w-40 and no more loud injectors. I got 102k miles on this truck and decided this will be the oil I'll run from here on.
Ford e-150 synthetic oil and seal craniac 1968-2013 Full Size Vans 5 07-28-2015 12:25 PM
Schaeffer or Amsoil Major Marvin 1994.5 - 1997 7.3L Power Stroke Diesel 42 03-25-2011 03:33 PM
Synthetic Oil for a 2005 Expedition froger25 1997-2006 Expedition & Navigator 5 06-02-2006 07:19 AM
Has anyone heard of Synergyn oils??? ahkmn Oil & Lubrication 4 05-04-2003 11:04 AM
Synthetic oil gembeau Oil & Lubrication 4 08-14-2001 02:36 AM
Tags
10w, 2007, 3000, 5w30, 60, amsoil, diesel, f250, f350, ford, hdd, motor, oil, quarts, series, synthetic, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
