Can't remove drive shaft - Ford Truck Enthusiasts Forums
Old 06-10-2009, 11:26 PM
justin_brandstein's Avatar
justin_brandstein justin_brandstein is offline
justin_brandstein is starting off with a positive reputation.
Guys on my f-150 I cant get the shaft off to replace u-joints. I have the four bolts on the rear flange removed but it wont budge. What is wrong?
Old 06-10-2009, 11:36 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
1st make sure the tires are blocked
2nd get a prybar between the yolk and the u joint and pry it apart, they freeze in quite often
Old 06-10-2009, 11:38 PM
Are you talking about on the rear part of the driveshaft? Im not sure how i could fit it in with the flange there
Old 06-10-2009, 11:43 PM
yes. you can prob get a 1/2" prybar in there
Old 06-11-2009, 08:46 AM
currituckF150's Avatar
currituckF150 currituckF150 is offline
currituckF150 is starting off with a positive reputation.
+1 & spray some penetrating oil on the bolts
Old 06-11-2009, 12:40 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
+1
If you didn't use the parking brake, or engaged it while the tranny was in park (or left in gear if manual), the driveshaft may be holding the vehicle in place. To relieve the tension, make sure the tires are blocked securely (so it can't roll either direction), then put the tranny in neutral. The truck may wiggle some, thats normal.
Then use a pry bar, lube, BFH, etc... and it should come off. If using BFH, only tap on the flange or U-joint, don't dent the shaft itself.
Old 06-12-2009, 12:02 AM
Ok I think I have confused people. The shaft is only bolted in the rear with four bolts to the rear end. The drive shaft wont come off the rear end though
Old 06-12-2009, 12:06 AM
__________________
Old 06-12-2009, 12:08 AM
Moore558's Avatar
Moore558 Moore558 is offline
Moore558 is starting off with a positive reputation.
Like they said before, block the rear wheels and put the truck in neutral to help get any tension off of the driveshaft. Then get you a hammer (plastic or brass is preferable) and tap on the flange part with moderate force and it should start to move a little till and you should be able to get it to "pop" off. I had to do this when I replaced my u-joints a few months ago. Just be careful not to hit the driveshaft with the hammer.
Old 06-12-2009, 06:59 AM
trk98 trk98 is offline
trk98 is starting off with a positive reputation.
+1 ^ Was typing the same thing, and went back and read Moore's post. Good luck
Old 06-12-2009, 07:16 AM
fmr9 fmr9 is offline
fmr9 is gaining momentum as a positive member of FTE.
Quote:
You got me conused. The normal way to pull the shaft is to take off two U bolts, 4 nuts, that hold the Ujoints firmly seated against the yolk. Then pry wiggle beat the shaft back a bit to get the ujoints out of their position so the entire shaft drops down and then slides towards the back. Is this what you are trying to do?
Good Luck Frank
Old 06-12-2009, 10:44 AM
not to be rude, but if you cant figure this out you shouldn't work on a truck
Pry here after bolts are removed
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view&current=000_0552.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0552.jpg" border="0" alt="Photobucket"></a>
or hit here
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view&current=000_0553.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0553.jpg" border="0" alt="Photobucket"></a>
Old 06-12-2009, 11:00 AM
Moore558's Avatar
A lot of the 8.8" rear axles that I've seen (my truck included) have the rear u-joint pressed into a flange that then uses four bolts to attach to the pinion flange on the rear differential. What the u-joints press into looks similar to this.
http://www.dennysdriveshaft.com/img/...dsSmallBol.jpg
Old 06-12-2009, 11:10 AM
Valid point. Still hit where i am pointing w a hammer and the shaft will fall off. Good luck w changing the joints if you are haveing this much trouble getting the shaft out
Old 07-19-2010, 09:43 AM
csonni csonni is offline
csonni is starting off with a positive reputation.
I've got my shaft on my 1980 F-150 to drop down (by prying) but how in the world do I get the front of the shaft to slip out of the center bearing support to remove the shaft? It won't budge.
T98 output shaft crown nut thread direction??? Rocketman55 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 10-11-2013 08:28 PM
Steering wheel shaft Radster 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-08-2012 09:58 AM
Dana 50 stub shaft removal? CSIPSD 1999 - 2003 7.3L Power Stroke Diesel 17 07-11-2010 05:22 PM
ouch, broken pinion shaft bolt arnold 2004 - 2008 F150 9 11-11-2007 11:46 PM
rear half shaft removal derwood9 New Member Introductions 1 09-15-2007 04:30 PM
Tags
1980, 2001, 96, bolts, drive, driveline, driveshaft, f150, ford, pickup, rear, removal, remove, removing, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
