CODE636 TPS Voltage above normal
'92 F150 5.0l 302.
New motocraft Idle Air Control Valve
New motocraft O2 sensor
New NAPA TPS
Just wondering if the TPS yet as well needs to be motocraft or is there something else I need to be looking into that is giving the code 636 throttle position sensor voltage above normal.
Thank you for any advice/ answer.
Markes12344
New NAPA TPS
Markes12344
'92 F150 5.0l 302.
New NAPA TPS
Markes12344
New NAPA TPS
Markes12344
Tot = transmission oil temperature
Might be result running self test engine and trans not fully up to running temperature, might be a problem with the sensor or the computers connection with it.
Can test the TOT sensor see if it falls within range for given temp.
Should be Gray-red and ORG-blk wires, pins 42 and 46 PCM main harness connector (I'd test it there first)
All temps given in F,
32 - 58 = 37 - 100k
58 - 104 = 16 - 37k
105 - 158 = 5 - 16k
195 - 230 = 2.7 - 5k
195 - 230 = 1.5 - 2.7K
231 - 266 = 0.8 - 1.5K
the holes for mounting are slotted i noticed the notch within the tps for the bottom of the throttle rod to insert into. i do know it made proper insertion to the notch, [and i installed the tps so the wire was coming out the same side as factory.] my only thought of the improper install would be that with the slotted mounting holes i should rotate the tps to the other end of the slotted holes.
My Innova OBD1 scan gave the code 636, with the plain English translation saying, Ford KOEO, Throttle Position sensor voltage above normal.
With that being said I'm not saying the device can be wrong, if it does have to do with the TOT than I will have to manually test resistance. plus the engine was warm, but the transmission was by far not warm.
I will convert temps to centigrade, then do the ohms test on the leads.
If all else fails. Guess their may be further research needing done.
Thanx for the aid so far.
Markes12344
Define correctly please.
Markes12344
Markes12344
At first I thought you where asking two different questions, one about the TPS and then one about TOT. Realized both one in the same after reading it again, knowing TPS codes are in the 120's trans in the 600's.
Manual for E4OD only lists two digit codes, 26 = same thing though "out of self test range", make sure the trans is warm, up to full running temp then rerun test again before doing doing bunch of resistance testing etc.
I could/would have included those temps in "centigrade" already but figured just want Fahrenheit, incorrect assumption on my part being in USA must admit didn't notice the "Ontario" part! sorry bout that...
WesternFord
04-01-2008 08:44 AM
John7894
01-14-2003 04:41 PM
