Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 06-10-2009, 07:01 PM
99expy 99expy is offline
Garage is empty, add now
99expy is starting off with a positive reputation.
tires
I will be replacing tires at some point. I have always bought Michelin but the selection is limited for P25570R18 tires. Any suggestions for replacements? I don't want to replace them with the OEM Pirrelli Scorpion tires, they're not good in the snow. If I go up to P26570R18 the selection is greater. Are there any significant issues with a slighter wider tire?
Thanks
  #2 (permalink)
Old 06-10-2009, 11:18 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
I don't see any problems going to the 265. The size difference is almost neglegible so I wouldn't worry about it. You will be fine at that size.
  #3 (permalink)
Old 06-11-2009, 01:57 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
32" tall tires right?
check out the 275/65/18 tires...a very wide selection of tires. it's 31.8" tall, and about 10" wide
That is the OEM size for the newer Expy and F-150s
widers tires tend to "float" a bit more than tall narrow tires...but I've been running 265 and 275 width tires for 10+ years in the snow and mud. They do just fine...it's really a matter of getting a really good tire
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #4 (permalink)
Old 06-11-2009, 11:52 AM
Thanks for the info. I have a 2007 XLT with 22000 miles. Does changing the tire size affect the warranty and speedometer reading?
  #5 (permalink)
Old 06-12-2009, 11:00 AM
07EXPYEL 07EXPYEL is offline
07EXPYEL is starting off with a positive reputation.
I had more flats with my Scorpions than with any other tires. I found new P25570R18Michelin tires locally on craigslist for <$300 for the set that were take-off from newer stock Tundras. I was happy to save $500 in this economy.
  #6 (permalink)
Old 06-12-2009, 11:59 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Won't affect warranty and if the overall diameter is close, the speedo won't be off by much if any.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #7 (permalink)
Old 06-12-2009, 01:01 PM
welfarewagon welfarewagon is offline
welfarewagon is starting off with a positive reputation.
Quote:
How do you like your Michelin? I am waiting on a set to come Fed Ex as week speak. I assume they are LTX AS as that is all they make in that size.
Making a set of winter tires, I picked up a set of 18" 08 Expy rims for $275 on Ebay.
  #8 (permalink)
Old 06-12-2009, 01:15 PM
Quote:
I like them a lot. I had 2 sets of LTX's on my prior vehicle (van) and they rode well, lasted a long time, and were rather quiet. I'm not sure if this is what you're planning on for a winter tires, so I can't comment on how they perform for winter service. I just use mine for city, highway, dirt roads, and the ocassional snow (if we drive a couple of hours from Phoenix to take the kids to play in the snow).
  #9 (permalink)
Old 06-12-2009, 03:00 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
i had a set of the LTX M/S and I loved them
Almost 40,000 miles and they still plenty of tread life left. Went through 2 Winters with snow/ice and they were pretty decent
You get what you pay for, but they are expensive
__________________
  #10 (permalink)
Old 06-12-2009, 04:52 PM
The last Expedition I had I went through two sets of Cross Terrains and two sets of LTXs. I got an average of 40-50k on each set. The LTXs were a better tire in the snow. Both were pretty good wet and dry. I never had an issue with either tire. I can't buy either of them in the size I need. I'm looking at the Michelin Lattitude Tour or the General Grabber HTS.
Tags
highway, michelin, p25570r18, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
